BPI-Bit
The BPI-bit (also referred to as BPI:bit, stylised as webduino:bit) is an ESP32 with Xtensa 32bit LX6 single/dual-core processor based embedded system. support Webduino and arduino function.
BPI-bit hardware
BPI-bit hardware description
BPI:bit interface
BPI:bit edge interface
BPI-bit software
BPI:bit for webduino
BPI: bit Webduino Firmware Burning
Burning method:
One, ESP Flash Download Tool
Tool download address:ESP Flash Download Tool
Select ESP32 DownloadTool:
- File and burn position corresponding to::
bootloader_dio_40m.bin | 0x1000 |
partitions.bin | 0x8000 |
boot_app0.bin | 0xe000 |
bit_default.bin | 0x10000 |
- SpiFlashConfig:
SPI SPEED | 40NHz |
SPI MODE | DIO |
FLASH SIZE | 32Mbit |
COM | COMx(Fill in the port number assigned by the computer) |
BAUD | 1152000 |
During the burning process:
Finished:
webduino srouce code
BPI:bit for arduino
