BPI-Bit
Revision as of 01:55, 5 May 2018 by Sinovoip (talk | contribs) (BPI: bit Webduino Firmware Burning)
The BPI-bit (also referred to as BPI:bit, stylised as webduino:bit) is an ESP32 with Xtensa 32bit LX6 single/dual-core processor based embedded system. support Webduino and arduino function.
BPI-bit hardware
BPI-bit hardware description
BPI:bit interface
BPI:bit edge interface
BPI-bit software
BPI:bit for webduino
Burning method:
One, ESP Flash Download Tool
Tool download address:ESP Flash Download Tool
Select ESP32 DownloadTool:
- File and burn position corresponding to::
bootloader_dio_40m.bin0x1000
partitions.bin0x8000
boot_app0.bin0xe000
bit_default.bin0x10000
- SpiFlashConfig:
SPI SPEED40NHz
SPI MODEDIO
FLASH SIZE32Mbit
COMCOMx(Fill in the port number assigned by the computer)
BAUD1152000
During the burning process:
Finished:
webduino srouce code
BPI:bit for arduino
