Banana Pi BPI-R3
Application direction
- . Internet service Router
- . Wireless Router
- . Wireless Repeater
- . Home security Gateyway
- . Home Automation
- . Nas device
- . 2G DDR RAM
- . 8G eMMC flash
- . 2 SFP 2.5GbE
- . 5 GbE network port
- . Mini PCIe via USB
- . M.2 KEY-E PCIe inerface
- . Mciro SD card interfact
- . 26 PIN GPIO
| CPU | MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53+MT7531 chip design | ||
| SDRAM | 2 GB LPDDR3 | ||
| On board Network | 5 Port 10/100/1000Mbps Ethernet | ||
| SFP | 2 SFP 2.5GbE | ||
| Wifi | Wifi 6/6E 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P) | ||
| M.2 interface | M.2 KEY-E PCIe inerface | ||
| USB | 1 USB 3.0 host ,2 USB interface with slot. | ||
| DC Power | 12V/2A with DC in | ||
| Weight | 200g | ||
Release image
- BPI-R3 OpenWRT 21.02 linux kerne 5.4, wifi 6E 2.4G and 5G working fine.
- Goole driver: https://drive.google.com/file/d/18_xst-diDdCg7CeSum1M5FDbbo31jFJq/view?usp=drivesdk
- baindu link : https://pan.baidu.com/s/1v1p4xO_f_HlZm7pENAgjoQ?pwd=x3tk pincode: x3tk
