StarFive VisionFive JH7100 RISC-V Single Board Computer
[hide]Introduction
StarFive VisionFive JH7100 is world‘s first generation of affordable RISC-V boards designed to run Linux. Based on RISC-V architecture, VisionFive pushes open-source to the next level and gives developers more freedom and power to innovate and design industry-leading solutions. This is not an official development board for the Banana Pi community, but the Banana Pi open Source community and StarFive work closely together to advance risC-V open source hardware.
VisionFive is the first generation of affordable RISC-V computers designed to run Linux. It is fully open-source with open-source software, open hardware design and RISC-V open architecture.It is powered by RISC-V SiFive U74 Dual-Core 64-bit RV64GC ISA SoC with 4GB/8GB LPDDR4 RAM variants and has rich I/O peripherals such as USB 3.0 ports, 40-pin GPIO header, Gigabit Ethernet Connector, Micro-SD card slot and much more.VisionFive also has rich AI features with Neural Network Engine and NVDLA Engine. It has onboard audio and video processing capabilities and has MIPI-CSI and MIPI-DSI connectors for video hardware. It has wireless capabilities with Wi-Fi and Bluetooth (BLE) and has a wide software compatibility including support for Fedora.
Features
- Truly open-source hardware, software and RISC-V open architecture
- Powerful and rich AI features with Neural Network Engine and NVDLA Engine
- Abundant I/O peripherals
- Wireless connectivity with Wi-Fi and BLE
- Onboard video and audio processing
- Wide software compatibility including support for Fedora linux
Specificationc | Details |
Processor | -RISC-V SiFive U74 Dual-Core 64-bit RV64GC ISA SoC with 2MB L2 cache @ 1.0GHz |
-Vision DSP Tensilica-VP6 for computing vision @ 600MHz | |
-NVDLA Engine (configuration 2048 MACs @ 800MHz) | |
-Neural Network Engine (1024MACs @ 500MHz) | |
Memory | 8GB LPDDR4 |
Wireless Connectivity | -2.4 GHz Wi-Fi (IEEE 802.11b/g/n),-Bluetooth 4.2 (BLE) |
Video Processing | -2 x MIPI-CSI (up to 4K@30fps), 1 x MIPI-DSI (up to 4K@30fps) |
-1 x HDMI 1.4 (up to 1080p@60fps display) | |
-Video Decoder (H264/H265) up to 4K@60fps; Support Dual stream decoding for 2K@30fps each | |
-Dual channels of ISP, each channel support up to 4K@30FPS | |
-Support MIPI-CSI TX for video output after ISP and AI processing | |
-JPEG encoder/decoder | |
Dedicated Audio Processing | -Ultra-low power Voice Activity Detector for audio bit-stream as a Voice Trigger |
DSP and Sub-system | -On-chip Audio DAC |
-Support DMIC and AMIC, up to 4 channels | |
Peripherals | -4 x USB 3.0 ports |
-40 Pin GPIO Header (28 x GPIO, I2C, I2S, SPI, UART) | |
-Gigabit Ethernet Connector | |
-3.5 mm Audio jack (4-pole stereo audio output) | |
-Micro-SD card slot for system boot and data storage | |
-Support TRNG and OTP | |
-Support DMAC, QSPI and other peripheral | |
-Reset button and Power Button | |
Power Supply | -Minimum: 5 V / 1.5 A,-Recommended: 5 V / 3 A |
Power Connector | -USB Type-C port or 40-pin GPIO header |
Dimensions | 100 mm x 72 mm |
