[hide]Description
The BPI-9600 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet(PoE) standard.
The BPI-9600 signature and control circuit provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 15W power to the port. The BPI-9600 provides a Class 0 signature.
The DC/DC converter operates over a wide input voltage range and provides a regulated output. The DC/DC converter also has built-in short-circuit output protection.
Features
- IEEE802.3af compliant
- Low output ripple and noise
- Short-circuit protection
- Adjustable Output
Applications
- IoT gateway
- IP Cameras
- Wireless access point
- Security and alarm systems
- VOIP telephone
PBI-9600 PoE Hardware
Module size
Product Selector
BPI-9600 PoE module | ||||
Part Number | Nominal Output Voltage | Maximum Output Power | Marking | Package |
BPI-9600-3.3V | 3.3V | 6.6W | 3.3V | SIL |
BPI-9600 -5V | 5V | 10W | 5V | SIL |
BPI-9600 -12V | 12V | 12W | 12V | SIL |
BPI-9600 -24V | 24V | 12W | 24V | SIL |
- At 25°C with VIN = 48V
Pin Description
Pin # | Name | Description | |
1 | VA1 | RX Input (1). This input pin is used in conjunction with VA2 and connects to the centre tap of the transformer connected to pins 1 & 2 of the RJ45 connector (RX) - it is not polarity sensitive. | |
2 | VA2 | TX Input (2). This input pin is used in conjunction with VA1 and connects to the centre tap of the transformer connected to pins 3 & 6 of the RJ45 connector (TX) - it is not polarity sensitive. | |
3 | VB1 | Direct Input (1). This input pin is used in conjunction with VB2 and connects to pin 4 & 5 of the RJ45 connector - it is not polarity sensitive. | |
4 | VB2 | Direct Input (2). This input pin is used in conjunction with VB1 and connects to pin 7 & 8 of the RJ45 connector - it is not polarity sensitive. | |
5 | -VDC | DC Return. This pin is the return path for the +VDC output. | |
6 | +VDC | DC Output. This pin provides the regulated output from the DC/DC converter. |
Absolute Maximum Ratings
BPI-9600 PoE module | |||||
Parameter | Symbol | Min | Max | Units | |
1 | DC Supply Voltage | VCC | -0.3 | 60 | V |
2 | DC Supply Voltage Surge for 1ms | VSURGE | -0.6 | 80 | V |
3 | Storage Temperature | TS | -40 | 100 | OC |
BPI-9600 PoE module | |||||||
Parameter | Symbol | Min | Typ | Max | Units | Units | |
1 | Input Supply Voltage1 | VIN | 36 | 48 | 57 | V | V |
2 | Under Voltage Lockout | VLOCK | 30 | 36 | V | V | |
3 | Operating Temperature2 | TOP | -20 | 25 | 70 | Ta / OC | BPI-9600 |
Note
- 1: With minimum load
DC Electrical Characteristics
Note
- 3: Continuous short circuit duration is applicable at 25'C ambient temperature in free air. At higher temperatures or with restricted
- airflow (e.g. in a sealed enclosure) the duration will need to be limited to avoid overheating.
Typical Connection Diagram
OEM&ODM
Products can be customized according to customer needs
