BPI-7604 IEEE 802.3af PoE Splitter module
Description
BPI-7402 IEEE 802.3at PoE module(12V 2A)
BPI-7604 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet(PoE) standard. BPI-7604 signature and control circuit provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 15W power to the port. BPI-7604 provides a Class 0 signature. BPI-7604 DC/DC converter operates over a wide input voltage range and provides a regulated output. The DC/DC converter also has built-in short-circuit output protection.
Application
- IP Cameras
- Wireless access point
- Security and alarm systems
- VOIP telephone
Main sprc
- IEEE802.3af compliant
- Integrated LAN Filters
- Regulated 12V DC output
- Low output ripple and noise
- Wide Input voltage range
- Overload and short-circuit protection
- 1500V isolation (input to output)
- Simple installation
- CE and FCC part 15 certified
- Enables PoE functionality for legacy products
Specification
| 1 | Input Voltage: 36 to 57 Vdc |
| 2 | Output power: 13W max. |
| 3 | Output current and voltage: 1.08A max. @ 12V +/-0.5V |
| 4 | Ripple: Typical 100mVp-p |
| 5 | Connectors: 2 x 8pin 1x 4pin 1.25mm |
| 6 | Ethernet Supported: 10/100-Base-T IEEE 802.3af |
| 7 | PoE Pin Assignment: 3/6, 1/2 or 4/5, 7/8 |
| 8 | Storage Temperature: -30°C to +80°C |
| 9 | Operating Humidity: 10% to 90%, non-condensing |
| 10 | Storage Humidity: 5% to 95%, non-condensing |
| 11 | Emissions & Immunity: FCC Part 15 Class A EN55022 (CISPR 22) Class B EN55024 (CISPR 24) |
| 12 | Safety: CE IEC 60950 |
| 13 | Reliability MTBF: 100,000 hours @ 25°C |
| 14 | Warranty : 1 Year |
| 15 | Dimensions: Height: 38 mm Width: 38mm Depth: 18mm Weight: 20 g |
| 16 | Operating Temperature: -20°C to +70°C |
Connector and Pin Description
| J1 | AUX IN 1.25mm | J3 | DC Putout 2 2.0mm |
| 1 | Ethernet cable spare pair 7,8 | 1 | 12V Output + |
| 2 | Ethernet cable spare pair 4,5 | 2 | 12V Output - |
| 3 | DC Auxiliary input 12V- | ||
| 4 | DC Auxiliary input 12V+ |
| J2 | POE_IN 1.25mm | J4 | NET out 1.25mm |
| 1 | LED- Internal connection J3 | 1 | 12V Output - |
| 2 | LED+ Internal connection J3 | 2 | 12V Output + |
| 3 | Ethernet cable 6 | 3 | LED- Internal connection J1 |
| 4 | Ethernet cable 3 | 4 | LED+ Internal connection J1 |
| 5 | Ethernet cable 2 | 5 | Ethernet cable 1 |
| 6 | Ethernet cable 1 | 6 | Ethernet cable 2 |
| 7 | Ethernet cable 3 | ||
| 8 | Ethernet cable 6 |
Package Size
Typical Connection in IP Cameras
OEM&ODM
Products can be customized according to customer needs
