BPI-9460 IEEE 802.3af Isolation Model PoE module
Revision as of 22:38, 27 February 2022 by Sinovoip (talk | contribs) (RT9460S Typical Connection Diagram)
Description
The BPI-9460 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet(PoE) standard. The BPI-9460 signature and control circuit provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 15W power to the port. The RT9460 provides a Class 0 signature.The DC/DC converter operates over a wide input voltage range and provides a regulated output. The DC/DC converter also has built-in short-circuit output protection.
Applications
  • IP Cameras
  • Wireless access point
  • Security and alarm systems
  • VOIP telephone
Features
  • IEEE802.3af compliant
  • Input voltage range 36V to 57V
  • Integral high efficiency DC/DC converter.
  • Low output ripple and noise
  • High performance with low price
  • Short-circuit protection
  • Adjustable Output
  • Optional multi-voltage output 3.3V 5V 12V 24V
  • Transformer isolation ,1500V isolation (input to output)
  • Easy to use, with a minimum number of external components.
  • Rohs compliantnt
BPI-9460 Product Selector
Part Number Nominal Output Voltage Output current Maximum Output Power* Marking Package
BPI-9460S-3.3V 3.3V 2A 10W** 3.3V SIL
BPI-9460S -5V 5V 2.4A 13W** 5V SIL
BPI-9460S -12V 12V 1A 13W** 12V SIL
BPI-9460S -24V 24V 0.5A 13W** 24V SIL
  • At 25°C with VIN = 48V
    • Maximum Output Power: means it not could be operated in continuous stage .only short-term of Boot up/Heavy loading
Absolute Maximum Ratings
  Parameter Symbol Min Max Units
1 DC Supply Voltage VCC -0.3 60 V
2 DC Supply Voltage Surge for 1ms VSURGE -0.6 80 V
3 Storage Temperature TS -40 100 OC
  Parameter Symbol Min Typ Max Units
1 Input Supply Voltage1 VIN 36 48 57 V
2 Under Voltage Lockout VLOCK 30   36 V
3 Operating Temperature2 TOP -20 25 70 Ta / OC
Note
  • 1: With minimum load
  • 2: See Section Operating Temperature Range
    • Extended use close to, or at the maximum operating temperature can reduce the life time of the device.
Pin Description:
Pin # Name Description
1 VA1 RX Input (1). This input pin is used in conjunction with VA2 and connects to the centre tap of the transformer connected to pins 1&2 of the RJ45 connector (RX) - it is not polarity sensitive.BPI-9460S this pin is direct Input +. This pin connects to the positive (+) output of the input bridge rectifier.
2 VA2 TX Input (2). This input pin is used in conjunction with VA1 and connects to the centre tap of the transformer connected to pins 3&6 of the RJ45 connector (TX) - it is not polarity sensitive.BPI-9460S this pin is direct Input -. This pin connects to the negative (-) output of the input bridge rectifier.
3 VB1 Direct Input (1). This input pin is used in conjunction with VB2 and connects to pin 4 & 5 of the RJ45 connector - it is not polarity sensitive.BPI-9460S this pin is direct Input +. This pin connects to the positive (+) output of the input bridge rectifier.
4 VB2 Direct Input (2). This input pin is used in conjunction with VB1 and connects to pin 7 & 8 of the RJ45 connector - it is not polarity sensitive.BPI-9460S this pin is direct Input -. This pin connects to the negative (-) output of the input bridge rectifier
5 -VDC DC Return. This pin is the return path for the +VDC output.
6 +VDC DC Output. This pin provides the regulated output from the DC/DC converter.
7 ADJ Output Adjust. The output voltage can be adjusted from is nominal value, by connecting an external resistor from this pin to either the +VDC pin or the -VDC pin.
DC Electrical Characteristics
9406.png Note
  • 1: Typical figures are at 25°C with a nominal 48V supply and are for design aid only. Not Guaranteed
  • 2: The output ripple and noise can be reduced with an external filter, see application note.
  • 3: Continuous short circuit duration is applicable at 25'C ambient temperature in free air. At higher temperatures or with restricted airflow (e.g. in a sealed enclosure) the duration will need to be limited to avoid overheating.
Reducing the output voltage, connect R2 between ADJ and +VDC
  R2 Value output voltage R2 Value output voltage
BPI-9460-3.3V	open	3.3V	0R	2.8V
BPI-9460-5V	open	5V	0R	4.4V
BPI-9460-12V	open	12V	0R	9.9V
BPI-9460-24V	open	24V	30K	18.2V
Increasing the output voltage, connect R1 between ADJ and -VDC
  R1 Value output voltage R1 Value output voltage
BPI-9460-3.3V	open	3.3V	0R	3.7V
BPI-9460-5V	open	5V	0R	5.7V
BPI-9460-12V	open	12V	0R	12.8V
BPI-9460-24V	open	24V	0R	25.5V
