BPI-7604 IEEE 802.3af PoE Splitter module
Description
BPI-7604 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet(PoE) standard. BPI-7604 signature and control circuit provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 15W power to the port. BPI-7604 provides a Class 0 signature. BPI-7604 DC/DC converter operates over a wide input voltage range and provides a regulated output. The DC/DC converter also has built-in short-circuit output protection.
Application
  • IP Cameras
  • Wireless access point
  • Security and alarm systems
  • VOIP telephone
Main sprc
  • IEEE802.3af compliant
  • Integrated LAN Filters
  • Regulated 12V DC output
  • Low output ripple and noise
  • Wide Input voltage range
  • Overload and short-circuit protection
  • 1500V isolation (input to output)
  • Simple installation
  • CE and FCC part 15 certified
  • Enables PoE functionality for legacy products
Connector and Pin Description
J1 AUX IN 1.25mm J3 DC Putout 2 2.0mm
1 Ethernet cable spare pair 7,8 1 12V Output +
2 Ethernet cable spare pair 4,5 2 12V Output -
3 DC Auxiliary input 12V-
4 DC Auxiliary input 12V+
|J2 || POE_IN 1.25mm|| J4 ||NET out 1.25mm |1 LED- Internal connection J3|| 1 ||12V Output - |2 LED+ Internal connection J3 ||2 || 12V Output + |3 Ethernet cable 6 ||3 ||LED- Internal connection J1 |4 Ethernet cable 3 ||4 ||LED+ Internal connection J1 |5 Ethernet cable 2 ||5 ||Ethernet cable 1 |6 Ethernet cable 1 || 6 ||Ethernet cable 2 | ||7 ||Ethernet cable 3 | ||8 ||Ethernet cable 6 |}
