Getting Started with M4
Revision as of 02:20, 13 December 2021 by Dangku (talk | contribs) (→Enable SPI)
BPI-M4
Overview Banana Pi BPI-M4
Overview:Realtek RTD1395
  • 8G eMMC flash (max 64 GB)
  • USB 2.0 TYPE C
  • PoE function support
Development For Android
Install Android Image
Download the latest android image
Download BPI-M4 USB flash tool
Note:
 1. BPI-M4 Android8 image only support 2GB ddr board.
 2. BPI-M4 USB flash tool is a usb download tool for flashing android image to board emmc, and only support Windows platform.
 3. Make sure SW2 (board bottom near sd slot) switch to 1
 4. Read document/bananapi_m4_usb_download_tool_guide.doc before flashing image.
Development For Linux
Install Linux Image
Download the latest Linux image
Note:
1. Board SW2 (board bottom near sd slot) switch to 0
2. For the compatibility of new 2GB and 1GB board with one Linux image, the old batch (before May, 2020) 1GB board must update the spirom firmware, so it can run the new release image.
3. Login user/password: pi/bananapi or root/bananapi
1.Install bpi-tools on your linux
    $ apt-get install pv
If you can't access this URL or any other problems, please go to bpi-tools repo and install this tools manually.
2.Insert your TF card into your PC
    $ bpi-copy xxx.img /dev/sdX
Actually bpi-copy is the same as this dd command
    $ sudo unzip -p xxx-bpi-m4-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
1.Prepare a sd which is installed ubuntu image and bootup with sdcard
2.Copy emmc image to udisk, plug in board, then mount udisk.
3.After mount udisk, use bpi-copy command to install image on Emmc.
    $ sudo bpi-copy xxx-bpi-m4-xxx.img.zip /dev/mmcblk1
    $ sudo unzip -p xxx-bpi-m4-xxx.img.zip | pv | dd of=/dev/mmcblk1 bs=10M status=noxfer
4.After success install, power off the board, eject the sdcard and poweron with emmc boot.
Enable SPI
Without device-tree overlay support, 40pin header SPI function is disabled default because pins multiplexing with uart2, it can be enabled according to this topic
https://forum.banana-pi.org/t/banana-pi-bpi-m4-how-to-get-i2c-and-spi-running-tutorial/12824
or by fdtput command without building kernel. Make sure boot partition mounted before doing this.
 # fdtput -t s /media/pi/BPI-BOOT/bananapi/bpi-m4/linux/rtd-1395-bananapi-m4-2GB.dtb /spi@9801BD00 status okay
 # fdtput -t s /media/pi/BPI-BOOT/bananapi/bpi-m4/linux/rtd-1395-bananapi-m4-1GB.dtb /spi@9801BD00 status okay
 # reboot
Installed Docker
EMAC
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On M3 console:
You have two ways to setup BT
1. Use commands to setup BT
  • Execute "bluetoothctl"
  • Execute these commands:
2. Use UI interface to setup BT
WiFi on M4
  • ip link set wlan0 up
 network={
 ssid="ssid"
 psk="password"
 priority=1
  • dhclient wlan0
