Banana Pi BPI-R2 Pro
File:Banana Pi BPI-R2 Pro .jpg
- Rockchip RK3568 Quad-core ARM Cortex-A55 CPU
- Mali-G52 1-Core-2EE
- 2G LPDDR4 SDRAM (option 4G)
- Mini PCIE interface and M.2 key-e interface
- support 1 SATA interface
- 16G eMMC flash (option 16/32/64G)
- 2 MIPI display interface support
- 1 CSI camera interface
| Banana Pi R2 Pro | |
| CPU | Rockchip RK3568 Quad-core ARM Cortex-A55 CPU 2GHz |
| GPU | Mali-G52 1-Core-2EE OpenGL ES3.2 Vu1kn 1.1 OpenCL 2.0 |
| Memory | 2G DDR3 SDRAM (option 4G) |
| Storage | Onboard 16GB eMMC Flash, Micro SD-Card slot, SATA 2.0 Port,SPI flash |
| Network | 5 x 10/100/1000 Mbit/s Ethernet |
| Display(s) | 1 HDMI port, 2 DSI interface(1 DSI can change to LVDS by software) |
| Camera | 1 CSI camera interfact |
| Video decoder(s) | H.265 HEVC/MVC Main10 Profile [email protected] up to 4096x2304@60fps,H.264 AVC/MVC Main10 Profile yuv400/yuv420/yuv422/@L5.1 up to 4096x2304@60fps |
| Video encoder(s) | H.264/AVC BP/MP/[email protected],up to 1920x1080@100fps, H.265/HEVC [email protected], up to 1920x1080@100fps (4096x4096@10fps with TILE) |
| Audio Output(s) | HDMI & I2S & Speaker & Headphone |
| USB port | USB 3.0 PORT (x2), micro USB OTG (x1) |
| mini PCIE | 1 mini pcie interface & 1 M.2 key-e interface |
| Remote | IR Receiver (x1) |
| Power Source | 12 volt @2A via DC Power and/or Micro USB (OTG) |
| Size & Weight | 148 mm × 100.5mm 100g |
| OS | OpenWRT, Linux and others OS |
Rockchip RK3568
RK3568 has built-in MICRO-research NPU of Rochip, 0.8Tops computing power and integrated high performance AI accelerator RKNN NPU. Rockchip also provides developers with an easy-to-use model transformation tool, RKNN-Toolkit, which supports one-click transformation of Caffe/TensorFlow/TF-Lite/ONNX/PyTorch/Keras/Darknet mainstream architecture models.
Source Code
documents
- Rockchip RK3568 datasheet: https://drive.google.com/file/d/18_MCl-3p0iDTzeady8N40X_qUbECTNmd/view?usp=sharing
- Rockchip RK809 PMIC datasheet: https://drive.google.com/file/d/18jObGuXCguS_hIth9JKEoEQXWTmcJQMI/view?usp=sharing
- RTL8367RB-VB-CG Switch chip datasheet: https://drive.google.com/file/d/18jObGuXCguS_hIth9JKEoEQXWTmcJQMI/view?usp=sharing
