Banana Pi BPI-R2 Pro
Revision as of 23:41, 22 October 2021 by Sinovoip (talk | contribs)
Rockchip RK3568 chip
File:Banana Pi BPI-R2 Pro .jpg
  • Mali-G52 1-Core-2EE
  • 2G LPDDR4 SDRAM (option 4G)
  • support 1 SATA interface
  • 1 CSI camera interface
File:BPI-R2 interface.png
Banana Pi R2 Pro
Storage Onboard 16GB eMMC Flash, Micro SD-Card slot, SATA 2.0 Port,SPI flash
Camera 1 CSI camera interfact
Video decoder(s) H.265 HEVC/MVC Main10 Profile yuv420@L5.1 up to 4096x2304@60fps,H.264 AVC/MVC Main10 Profile yuv400/yuv420/yuv422/@L5.1 up to 4096x2304@60fps
Video encoder(s) H.264/AVC BP/MP/HP@level4.2,up to 1920x1080@100fps, H.265/HEVC MP@level4.1, up to 1920x1080@100fps (4096x4096@10fps with TILE)
Remote IR Receiver (x1)
LED Power Status and 8P8C
Rockchip RK3568
RK3568 is a high-performance and low power quad-core application processor designed for personal mobile internet device and AIoT equipments. Many embedded powerful hardware engines are provided to optimize performance for high�end application. RK3568 supports almost full-format H.264 decoder by 4K@60fps, H.265 decoder by 4K@60fps, also support H.264/H.265 encoder by 1080p@60fps, high-quality JPEG encoder/decoder.Embedded 3D GPU makes RK3568 completely compatible with OpenGL ES 1.1/2.0/3.2, OpenCL 2.0 and Vulkan 1.1. Special 2D hardware engine will maximize display performance and provide very smoothly operation.The build-in NPU supports INT8/INT16/FP16/BFP16 hybrid operation. In addition, with its strong compatibility, network models based on a series of frameworks such as TensorFlow/MXNet/PyTorch/Caffe can be easily converted.
Source Code
documents
Release
