Getting Started with BPI-QCar
About BPI-QCar
BPI Q-Car with micro:bit
BPI Q-Car with BPI-Bit
BPI-QCar with BPI-AI board
  • support Micro:bit, PBI:bit(Web:bit) and BPI-AI(WEB:AI) boards
  • support Makecode graphical programming(with micro:bit),support Webduino graphical programming(with BPI:bit),and it also support MicroPython arduino(Micro:bit/BPI:bit)
  • Compact body, strong integrity
  • N20 Miniature reducer
  • Infrared emission, infrared reception, line patrol, speed measurement, atmosphere lamp, I2C interface (support 3.3V and 5V), ultrasonic interface, buzzer, steering gear interface, needle row expansion port, expansion screw hole, etc...Fully functional, strong expansibility
  • Easy to use it.
Motor control
Ambient light control
Ultrasonic sensor control
How to use buzzer
Arduino code link:https://github.com/BPI-STEAM/Q-Car/tree/master/SoftWare/Web_Bit_Arduino/Buzzer_Demo
IR control
Objective: To master the infrared remote control of Q-CAR
Program effect display: infrared remote control Q-CAR forward and backward and turn
Arduino code link:https://github.com/BPI-STEAM/Q-Car/tree/master/SoftWare/Web_Bit_Arduino/IR_Control_Demo
Ultrasonic obstacle avoidance
Program effect display: boot the car forward, ultrasonic detection of the front distance, if the distance is less than 8cm, the car left and right to check the obstacles on both sides, choose the direction of the farther distance to turn, to avoid obstacles.
Arduino code link:https://github.com/BPI-STEAM/Q-Car/tree/master/SoftWare/Web_Bit_Arduino/Avoidance_Demo
Line patrol
BPI-QCar with BPI:Bit use MicroPython
BPI-QCar with Micro:Bit use MakeCode
MakeCode programming to light up the LED on Micro:Bit
Learning Objectives: Familiarize yourself with basic Makecode applications and display some graphics or text on the Micro:Bit 5*5LED matrix.
Open the Makecode programming environment web side of Micro:Bit:https://makecode.microbit.org/
Create a new project and connect the Makecode blocks with the following routine. For example, the first block "Show Leds" can be found in the "Basic" options column. This block can edit the desired graphics
Right-click building blocks to carry out some operations on the building blocks, such as add notes, delete copy building blocks, as well as access to the corresponding documentation of the building blocks, this for the first time people can provide great help.
The MakeCode programming environment has an emulator with its own simulation of the program to view the effect in real time, usually displayed at the top left
The Makecode programming environment also supports importing project files from outside, such as.hex files that are compiled by Makecode
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-display-graphics.hex
The project file can be imported into Makecode to view and edit after downloading to local, or it can be directly burned into Micro:Bit through USB and run directly
Micro:bit's Button control - Base
Learning Objectives: Use the two buttons A/B on Micro:Bit to control the graphics to be output by the LED matrix
On the basis of the section "Using Makecode Programming to Light Micro:Bit", find the building block "On Button A Pressed" in the "Input" option column of Makecode to program
The routine is shown in the figure below. Press the A button to display the English character "A", press the B button to display the English character "B", and press the AB button to display A pattern shaped like A banana
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Using_the_button_1.hex
Micro:bit's Button control -advanced
Learning objectives: Makecode programming to achieve a count and display button control procedures
Building on the previous section, create a new variable called "A_was_pressed_times" in the "Variables" section of the Makecode. This will generate multiple building blocks for the variable in the "Variables" section
Combine the addition blocks in the "Math" TAB and the Mosaic blocks in the "Variables" TAB. Refer to the following legend
At this point, we realized in the Makecode programming and made A use of the addition counting program, press A button A count to add 1 at the same time the counting value output to the LED matrix, press A button B count to return to 0 and clear the LED matrix display
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Using_the_button_2.hex
The wheel speed measurement
Learning Objectives: Using Makecode programming to read the high and low level signals of the infrared pair tube used for wheel speed measurement on BPI-QCAR and calculate the wheel speed with counting method
The routine is as shown in the figure below. The program is burned into Micro:bit, and the Micro:bit is connected to BPI-QCar. At this time, the left and right wheels of Q-CAR can be read from the USB serial port to the left and right wheel speed
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Q-Car_velocity_measurement_module.hex
Motor control
Learning Objectives: Using Makecode programming to achieve QCar left and right motor forward and reverse control
Routines as shown in the figure below, the program is burned into the Micro: BIT, the Micro: BIT and Q-CAR connection. Press the a button onceleft ,and right motor will be turned to 2s at the same time, reverse 2s at the same time, right motor is turned to 2s alone, left motor is turned to 2s alone,two motors stop.
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Q-Car_Motor_control_module.hex
Learning Objectives: Use Makecode programming to control 10 WS2812B color atmosphere lamps on BPI-QCar
The routine is as shown in the figure below. The program is burned into the Micro: BIT, and the Micro: BIT is connected to the Q-CAR. The 10 WS2812B lights on the Q-CAR will simultaneously cycle the rainbow light effect with 1800ms
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Q-Car_Pixel.hex
Learning Objectives: Using Makecode programming to control the HC-SR04 ultrasonic extension module on BPI-QCar
Routine as shown below, burn the program into Micro:BIT, connect Micro:BIT with BPI-QCar, connect HC-SR04 ultrasonic extension module with BPI-QCar, connect 5V power supply with BPI-QCar
The distance detected by the ultrasonic sensor and the temperature sensor data on the Micro:Bit can be read from the USB serial port of the Micro:Bit. The temperature calibration of the ultrasonic sensor is realized by the routine
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Q-car_Ultrasonic_ranging.hex
Use the buzzer
Learning Objectives: Write a piece of music with Makecode and play it on the BPI-QCar buzzer
The routine is shown in the figure below. Burn the program into Micro:Bit, connect Micro:Bit to BPI-QCar,press the a button once,and the buzzer on BPI-QCar will play the song twice in a cycle
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Q-car_Music_Arrangement.hex
Line patrol
Learning Objectives: using makecode programming to realize BPI-QCar line patrol driving, line patrol infrared tube analog value calibration, ultrasonic ranging and parking in case of obstacles
Routine as shown in the figure below, the program burned into the Micro:Bit , will Micro:Bit Connect with BPI-QCar and turn on the power switch,
When the right arrow is displayed in the LED matrix, align the two infrared couplers at the bottom and front of the BPI-QCar horizontally and place them directly above the line inspection line,
Press button B and wait for the calibration procedure to be completed. The left arrow will be displayed on the LED matrix. At this time, the front of BPI-QCar will face the line direction,
Press button A, BPI-QCar will start to patrol the line. If the ultrasonic ranging module detects that there is an object with a distance of less than or equal to 10 cm in front of it, it will stop
Routine project file:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Q-car_Line_tracking.hex
