Banana Pi BPI-M5
BPI-M5 Introduction
Banana Pi BPI-M5
Amlogic S905X3 Processor
BPI-M5 case design
  • Mali-G31 GPU
  • 4GB LPDDR4
  • 16GB eMMC flash
  • 4 USB 3.0
  • 1 GbE ethernet
  • HDMI output
Hardware inerface
Memory 4 GB LPDDR4
USB ports USB 3.0 PORT (x4)
Size & Weight 92x60mm, 48g
OS Android and Linux
SDIO interface Wifi&BT
File:Wifibt module .jpeg
IR Yes Yes Yes N/A
BPI-M5 40PIN GPIO (CON2)
CON1-P02 VCC5V
CON1-P03 GPIOX_17 I2C_M2_SDA
CON1-P04 VCC5V
CON1-P05 GPIOX_18 I2C_M2_SCL
CON1-P07 GPIOX_5 SDIO_CMD
CON1-P08 GPIOX_12 UART_A_TX
CON1-P10 GPIOX_13 UART_A_RX
CON1-P11 GPIOX_3 SDIO_D3
CON1-P12 GPIOAO_8 TDMB_SCLK
CON1-P13 GPIOX_4 SDIO_CLK
CON1-P15 GPIOX_7 PWM_F
CON1-P16 GPIOX_0 SDIO_D0
CON1-P18 GPIOX_1 SDIO_D1
CON1-P19 GPIOX_8 PCM_DIN
CON1-P21 GPIOX_9 PCM_DOUT
CON1-P22 GPIOX_2 SDIO_D2
CON1-P23 GPIOX_11 PCM_CLK
CON1-P24 GPIOX_10 PCM_SYNC
CON1-P26 GPIOX_16 PWM_E
CON1-P27 GPIOA_14 I2C_M3_SDA
CON1-P28 GPIOA_15 I2C_M3_SCL
CON1-P29 GPIOX_14 UART_A_CTS
CON1-P31 GPIOX_15 UART_A_RTS
CON1-P32 GPIOX_19 PWM_B
CON1-P33 GPIOX_6 PWM_A
CON1-P35 GPIOAO_7 TDMB_FS
CON1-P36 GPIOH_5 SPDIF_IN
CON1-P37 GPIOAO_7 I2S_MCLK
CON1-P40 GPIOAO_4 TDMB_DOUT
BPI-M5 Debug UART(CON1)
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
Linux BSP source code
How to flash Android Image
How to flash Linux Image
MD5: cd6bc3cb4fba1b83e2e3f63fd49ba15b
  • 2021-06-21 release, Ubuntu Server 20.04 with kernel 4.9.241
MD5: 5c896c37eaa590cfbb8a6c7a5ba433a0
MD5: 4ea1d71a5ba1a8fa743e4c8abbe7569b
Third part image
CoreELEC
  • CoreELEC 19.2
Google Drive: https://drive.google.com/drive/folders/1Cx_DA90Tbr8_M_8eQd-NwFUOp3UTwhYt
Baidu Cloud : https://pan.baidu.com/s/15y4LNg4K-w0vrwMTcg5VGQ Pincode: j9aj
Volumio
Download:
Odroid Android image
Base on Odroid android source code and build for bananapi m5/m2pro
Download: https://drive.google.com/drive/folders/1u_CddlHvpAMu2VZJfIfUKTsFFyigCWig
Ubuntu Core 20
HuaWei OpenEuler
BPI-M5 github: https://github.com/BPI-SINOVOIP/BPI-M5-bsp
Discuss on fourm : http://forum.banana-pi.org/t/bpi-m5-run-huawei-openeuler-open-source-linux-system/12073
