BPI-Bit
Revision as of 01:48, 5 May 2018 by Sinovoip (talk | contribs) (BPI: bit Webduino Firmware Burning)
The BPI-bit (also referred to as BPI:bit, stylised as webduino:bit) is an ESP32 with Xtensa 32bit LX6 single/dual-core processor based embedded system. support Webduino and arduino function.
BPI-bit hardware
BPI-bit hardware description
BPI:bit interface
BPI:bit edge interface
BPI-bit software
BPI:bit for webduino
Burning method:
One, ESP Flash Download Tool
Tool download address:ESP Flash Download Tool
After downloading, unzip the archive and you will see an ESPFlashDownloadTool_v3.6.2.exe inside the folder. Open this shortcut and open an interface selection mode. Webduino burn 1.png
webduino srouce code
BPI:bit for arduino
