Banana Pi BPI-R2 Pro
BPI-R2 Pro same size as Banana Pi BPI-R2 , and interface is also same .so can use BPI-R2+ case.
File:BPI-R2 interface.png
Banana Pi R2 Pro
CPU Rockchip RK3568
GPU Mali 450 MP4 GPU
Storage Onboard 16GB eMMC Flash, Micro SD-Card slot, SATA 2.0 Port,SPI flash
Camera 1 CSI camera interfact
Remote IR Receiver (x1)
LED Power Status and 8P8C
Power Source 5 volt @3A via DC Power and/or Micro USB (OTG)
