Banana Pi BPI-M64
Revision as of 23:05, 9 May 2018 by Sinovoip (talk | contribs) (Win 10 IoT)
Overview:Allwinner A64
Banana Pi BPI-M64 is a 64-bit quad-core mini single board computer. It features 2GB of RAM and 8GB eMMC. It also has onboard WiFi and BT. On the ports side, the BPI-M64 has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, and lastly a DC power port. The processor is pin-to-pin comptialbe with R18, so it comes with two versions:M64 and M64-R18.
  • Allwinner A64 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor.
  • 2 GB DDR3 SDRAM
  • 8G EMMC
  • 10/100/1000Mbps Ethernet
  • WiFi (AP6212) & Bluetooth
Banana Pi M64
CPU Allwinner A64 64 bit Quad Core ARM Cortex A53 1.2 GHz CPU
GPU Dual core Mali 400 MP2 GPU
Storage MicroSD slot supports up to 256GB expansion & 8 G eMMC flash (option 16/32/64G)
Network 10/100/1000 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n + Bluetooth BT4.0
Video Output(s) high-definition video playback & 2K HDMI port and multi-channel audio output (NO H./X.265 capabilities)
Remote IR Receiver (x1)
LED Power Status and 8P8C
Size & Weight 92x60mm, 48g
OS Android and Linux
40 PIN GPIO of Banana pi BPI-M64
CON2-P01 VCC-3V3
CON2-P02 VCC-5V
CON2-P03 TWI1-SDA PH3
CON2-P04 VCC-5V
CON2-P05 TWI1-SCK PH2
CON2-P06 GND
CON2-P07 PH6 PH6
CON2-P08 UART2-TX PB0
CON2-P09 GND
CON2-P10 UART2-RX PB1
CON2-P11 PH7 PH7
CON2-P12 UART2-CTS PB3
CON2-P13 DMIC-CLK PH10
CON2-P14 GND
CON2-P15 DMIC-DIN PH11
CON2-P16 UART2-RTS PB2
CON2-P17 VCC-3V3
CON2-P18 PD4 PD4
CON2-P19 SPI1-MOSI PD2 UART4-TX
CON2-P20 GND
CON2-P21 SPI1-MISO PD3 UART4-RX
CON2-P22 PC0 PC0
CON2-P23 SPI1-CLK PD1 UART3-RX
CON2-P24 SPI1-CS PD0 UART3-TX
CON2-P25 GND
CON2-P26 PC2 PC2
CON2-P27 PC4 PC4
CON2-P28 PC3 PC3
CON2-P29 PC7 PC7
CON2-P30 GND
CON2-P31 PCM0-BCLK PB5
CON2-P32 PCM0-DIN PB7
CON2-P33 PCM0-SYNC PB4
CON2-P34 GND
CON2-P35 PCM0-DOUT PB6
CON2-P36 PL9 PL9
CON2-P37 PL12 PL12
CON2-P38 PL7 PL7
CON2-P39 GND
CON2-P40 PL8 PL8
CSI camer PIN define of Banana pi BPI-M64
CN5-P01 NC
CN5-P02 GND
CN5-P03 CSI0-SDA PE13
CN5-P04 CSI0-AVDD
CN5-P05 CSI0-SCK PE12
CN5-P06 CSI0-Reset PE16
CN5-P07 CSI0-VSYNC
CN5-P08 CSI0-PWDN PE17
CN5-P09 CSI0-HSYNC PE2
CN5-P10 CSI0-DVDD
CN5-P11 CSI0-DOVDD
CN5-P12 CSI0-D7 PE11
CN5-P13 CSI0-MCLK PE1
CN5-P14 CSI0-D6 PE10
CN5-P15 GND
CN5-P16 CSI0-D5 PE9
CN5-P17 CSI0-PCLK PE0
CN5-P18 CSI0-D4 PE8
CN5-P19 CSI0-D0 PE4
CN5-P20 CSI0-D3 PE7
CN5-P21 CSI0-D1 PE5
CN5-P22 CSI0-D2 PE6
CN5-P23 GND
CN5-P24 CSI0-AFVCC
MIPI DSI display PIN define of Banana pi BPI-M64
CN6-P01 VCC
CN6-P02 IPSOUT
CN6-P03 VCC
CN6-P04 IPSOUT
CN6-P05 GND
CN6-P06 IPSOUT
CN6-P07 GND
CN6-P08 IPSOUT
CN6-P09 NC
CN6-P10 GND
CN6-P11 NC
CN6-P12 DSI-D0N
CN6-P13 NC
CN6-P14 DSI-D0P
CN6-P15 NC
CN6-P16 GND
CN6-P17 TWI0-SDA PH1
CN6-P18 DSI-D1N
CN6-P19 TWI0-SCK PH0
CN6-P20 DSI-D1P
CN6-P21 CTP-INT PH4
CN6-P22 GND
CN6-P23 CTP-RST PH8
CN6-P24 DSI-CKN
CN6-P25 GND
CN6-P26 DSI-CKP
CN6-P27 LCD-BL-EN PD5
CN6-P28 GND
CN6-P29 LCD-RST PD6
CN6-P30 DSI-D2N
CN6-P31 LCD-PWR-EN PD7
CN6-P32 DSI-D2P
CN6-P33 GND
CN6-P34 GND
CN6-P35 LCD-PWM PL10
CN6-P36 DSI-D3N
CN6-P37 GND
CN6-P38 DSI-D3P
CN6-P39 NC
CN6-P40 GND
Uart PIN define of Banana pi BPI-M2+
CON2 P03 UART0-TXD PB8
CON2 P02 UART0-RXD PB9
CON2 P01 GND
Win 10 IoT
banana pi BPI-M64 IOT certifying pass by Microsoft:windows 10 iot core
link: https://azure.microsoft.com/en-us/documentation/articles/iot-hub-tested-configurations/
get start:
https://github.com/Azure/azure-iot-sdks/blob/master/doc/get_started/windows10-iot-core-banana-pi-bpi-m64-csharp.md
test on BPI-M64
discuss on forum: http://forum.banana-pi.org/t/banana-pi-bpi-m64-iot-certifying-pass-by-microsoft-windows-10-iot-core/2090
Windows 10 IoT Core for BPI-M64 Release Note
This document describes how to build AllWinner UEFI Firmware and bring a AllWinner dev board up with it. The AllWinner UEFI Firmware, as the major boot system for AllWinner-Windows platform, is based on the EDK2 framework which is open-source and with some AllWinner platform software packages injected.
Some updates:
1. Update the OS version to build v.10.0.15063.0 \(Creators Update\)
2. New page style of Device Portal, visit [1](https://deviceipaddr:8080) to check it
3. Built-in Cortana assistant, need to be enabled in settings page in default app and Device Portal
4. Support on-screen keyboard, need to be enabled in Device Portal
5. Enable 100M Ethernet and fix some bugs
6. Support built-in UART bus in A64 SoC\(not built in the ffu, later provide driver binary and deployment helper\)
7. Support built-in IR module in A64 SoC\(not built in the ffu, later provide source code and dev doc for developers in community\)
Known Issues:
Kernel debug is enabled by default. This will slow the bring-up process. If a kernel debug is not necessary for you, visit Device Portal and navigate to Processes->Run Command page, run this command to disable : Bcdedit /store C:\EFIESP\EFI\Microsoft\boot\BCD /set {default} debug off
An PnP bug in audio device may cause a blue screen when acting software shutdown
Ethernet device may not start with problem code 12 at the first time to bring up
And another bomb! I uploaded core driver binaries and packaging toolchains on GitHub!
Here is the repo address: https://github.com/Leeway213/BSP-aw1689
And also some driver source code here with A64 datasheet in readme: https://github.com/Leeway213/driver-samples
Welcome makers developers and anyone-elsers to post your feedback.
  • schematic diagram:
google driver : https://drive.google.com/file/d/0B4PAo2nW2KfnUE5tMGItNkZjMzg/view?usp=sharing
baidu cloud : http://pan.baidu.com/s/1kVRpcYb
Win 10 IoT
  • 2017-1-13 updae Win10 IoT Core beta0.2
baidu cloud :http://pan.baidu.com/s/1c2ce100
  • Win10 IoT Core 10586 beta0.1
download link : https://drive.google.com/open?id=0B_YnvHgh2rwjODJOSS1TdkRvcEk
baidu link : http://pan.baidu.com/s/1dEQyGgD
MD5: 1c09118cd45bf0c3b61d1846710a3649
kernel 4.4
  • 2018-4-17 update Ubuntu 16.04.4 with linux kernel 4.4.89
image name:2018-04-17-ubuntu-16.04-mate-desktop-demo3-k4.4.89-vdpau-3-mic-docker-bpi-r18-avs-aarch64-sd-emmc.img.zip
Google Drive: https://drive.google.com/open?id=1dlfo9LGNcrc-_cpKd1uJnrNx0PdonBnK
MD5: 4b7e163d260e58a39ba8905e7ed39943
Forum pthread:http://forum.banana-pi.org/t/bpi-r18-avs-new-image-ubuntu-16-04-4-with-linux-kernel-4-4-89-2018-4-17/5435
Kernel 3.10.105
  • 2017-08-14 update based on ubuntu 16.04.3 LTS Mate Desktop (64-bit),support BPI-M64 kernel 3.10.105
Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjN1h1U0xDYUxET00/view?usp=sharing
baidu cloud: http://pan.baidu.com/s/1pLkbdTT
MD5: ae34baa840874276858d936a7ca85c4f
Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-2017-08-14-ubuntu-16-04-mate-desktop-beta-aarch64-bpi-m64-sd-emmc/3695
  • 2017-08-13 debian 8.9 jessie Mate Desktop (64-bit),support BPI-M64 kernel 3.10.105
Google Drive:https://drive.google.com/file/d/0B_YnvHgh2rwjazlNRTRHei1NbmM/view?usp=sharing
baidu cloud:http://pan.baidu.com/s/1eSeTQeA
MD5: 9ddf067457ebaf193de63c5c7141446a
Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-2017-08-13-debian-8-jessie-mate-desktop-preview-aarch64-bpi-m64-sd-emmc/3694
Android 6.0
  • 2017-05-11 apdate
HDMI-Version
Google Drive:https://drive.google.com/open?id=0B_YnvHgh2rwjcF9USm1MWWtxSXc
Baidu Cloud:https://pan.baidu.com/s/1bHWhlW
MD5: f85281213b9c5b88008a487dd1b6963c
LCD-Version
Google Drive:https://drive.google.com/open?id=0B_YnvHgh2rwjdHpFbHJMQWtsbFk
Baidu Cloud:https://pan.baidu.com/s/1kVJVPGV
MD5:be27e4eced96d3de81d46e512fd978eb
forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-android-6-0-version-v3/3240/4
Image lownload link :https://www.armbian.com/bananapi-m64/
  • Armbian OS aarch64
download link:http://geektillithertz.com/wordpress/index.php/2017/01/04/armbian-os-banana-pi-m64/
Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-armbian-os-aarch64-for-bpi-m64-download/2724
Others
