Banana Pi BPI-M64
Banana Pi BPI-M64 is a 64-bit quad-core mini single board computer. It features 2GB of RAM and 8GB eMMC. It also has onboard WiFi and BT. On the ports side, the BPI-M64 has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, and lastly a DC power port. The processor is pin-to-pin comptialbe with R18, so it comes with two versions:M64 and M64-R18.
- Allwinner A64 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor.
- 2 GB DDR3 SDRAM
- 8G EMMC
- 10/100/1000Mbps Ethernet
- WiFi (AP6212) & Bluetooth
Banana Pi M64 | |
CPU | Allwinner A64 64 bit Quad Core ARM Cortex A53 1.2 GHz CPU |
GPU | Dual core Mali 400 MP2 GPU |
Memory | 2 GB LPDDR3 (shared with GPU) |
Storage | MicroSD slot supports up to 256GB expansion & 8 G eMMC flash (option 16/32/64G) |
Network | 10/100/1000 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n + Bluetooth BT4.0 |
Video Input(s) | A CSI input connector allows for the connection of a designed camera module |
Video Output(s) | high-definition video playback & 2K HDMI port and multi-channel audio output (NO H./X.265 capabilities) |
Audio Input(s) | On board microphone |
Audio Output(s) | 3.5mm jack and HDMI |
USB ports | USB 2.0 PORT (x2), USB OTG (x1) |
Remote | IR Receiver (x1) |
Switches | Reset, Power and U-boot |
LED | Power Status and 8P8C |
Size & Weight | 92x60mm, 48g |
OS | Android and Linux |
40 PIN GPIO of Banana pi BPI-M64 | |||
CON2-P01 | VCC-3V3 | ||
CON2-P02 | VCC-5V | ||
CON2-P03 | TWI1-SDA | PH3 | |
CON2-P04 | VCC-5V | ||
CON2-P05 | TWI1-SCK | PH2 | |
CON2-P06 | GND | ||
CON2-P07 | PH6 | PH6 | |
CON2-P08 | UART2-TX | PB0 | |
CON2-P09 | GND | ||
CON2-P10 | UART2-RX | PB1 | |
CON2-P11 | PH7 | PH7 | |
CON2-P12 | UART2-CTS | PB3 | |
CON2-P13 | DMIC-CLK | PH10 | |
CON2-P14 | GND | ||
CON2-P15 | DMIC-DIN | PH11 | |
CON2-P16 | UART2-RTS | PB2 | |
CON2-P17 | VCC-3V3 | ||
CON2-P18 | PD4 | PD4 | |
CON2-P19 | SPI1-MOSI | PD2 | UART4-TX |
CON2-P20 | GND | ||
CON2-P21 | SPI1-MISO | PD3 | UART4-RX |
CON2-P22 | PC0 | PC0 | |
CON2-P23 | SPI1-CLK | PD1 | UART3-RX |
CON2-P24 | SPI1-CS | PD0 | UART3-TX |
CON2-P25 | GND | ||
CON2-P26 | PC2 | PC2 | |
CON2-P27 | PC4 | PC4 | |
CON2-P28 | PC3 | PC3 | |
CON2-P29 | PC7 | PC7 | |
CON2-P30 | GND | ||
CON2-P31 | PCM0-BCLK | PB5 | |
CON2-P32 | PCM0-DIN | PB7 | |
CON2-P33 | PCM0-SYNC | PB4 | |
CON2-P34 | GND | ||
CON2-P35 | PCM0-DOUT | PB6 | |
CON2-P36 | PL9 | PL9 | |
CON2-P37 | PL12 | PL12 | |
CON2-P38 | PL7 | PL7 | |
CON2-P39 | GND | ||
CON2-P40 | PL8 | PL8 |
CSI camer PIN define of Banana pi BPI-M64 | |||
CN5-P01 | NC | ||
CN5-P02 | GND | ||
CN5-P03 | CSI0-SDA | PE13 | |
CN5-P04 | CSI0-AVDD | ||
CN5-P05 | CSI0-SCK | PE12 | |
CN5-P06 | CSI0-Reset | PE16 | |
CN5-P07 | CSI0-VSYNC | ||
CN5-P08 | CSI0-PWDN | PE17 | |
CN5-P09 | CSI0-HSYNC | PE2 | |
CN5-P10 | CSI0-DVDD | ||
CN5-P11 | CSI0-DOVDD | ||
CN5-P12 | CSI0-D7 | PE11 | |
CN5-P13 | CSI0-MCLK | PE1 | |
CN5-P14 | CSI0-D6 | PE10 | |
CN5-P15 | GND | ||
CN5-P16 | CSI0-D5 | PE9 | |
CN5-P17 | CSI0-PCLK | PE0 | |
CN5-P18 | CSI0-D4 | PE8 | |
CN5-P19 | CSI0-D0 | PE4 | |
CN5-P20 | CSI0-D3 | PE7 | |
CN5-P21 | CSI0-D1 | PE5 | |
CN5-P22 | CSI0-D2 | PE6 | |
CN5-P23 | GND | ||
CN5-P24 | CSI0-AFVCC |
MIPI DSI display PIN define of Banana pi BPI-M64 | |||
CN6-P01 | VCC | ||
CN6-P02 | IPSOUT | ||
CN6-P03 | VCC | ||
CN6-P04 | IPSOUT | ||
CN6-P05 | GND | ||
CN6-P06 | IPSOUT | ||
CN6-P07 | GND | ||
CN6-P08 | IPSOUT | ||
CN6-P09 | NC | ||
CN6-P10 | GND | ||
CN6-P11 | NC | ||
CN6-P12 | DSI-D0N | ||
CN6-P13 | NC | ||
CN6-P14 | DSI-D0P | ||
CN6-P15 | NC | ||
CN6-P16 | GND | ||
CN6-P17 | TWI0-SDA | PH1 | |
CN6-P18 | DSI-D1N | ||
CN6-P19 | TWI0-SCK | PH0 | |
CN6-P20 | DSI-D1P | ||
CN6-P21 | CTP-INT | PH4 | |
CN6-P22 | GND | ||
CN6-P23 | CTP-RST | PH8 | |
CN6-P24 | DSI-CKN | ||
CN6-P25 | GND | ||
CN6-P26 | DSI-CKP | ||
CN6-P27 | LCD-BL-EN | PD5 | |
CN6-P28 | GND | ||
CN6-P29 | LCD-RST | PD6 | |
CN6-P30 | DSI-D2N | ||
CN6-P31 | LCD-PWR-EN | PD7 | |
CN6-P32 | DSI-D2P | ||
CN6-P33 | GND | ||
CN6-P34 | GND | ||
CN6-P35 | LCD-PWM | PL10 | |
CN6-P36 | DSI-D3N | ||
CN6-P37 | GND | ||
CN6-P38 | DSI-D3P | ||
CN6-P39 | NC | ||
CN6-P40 | GND |
Uart PIN define of Banana pi BPI-M2+ | |||
CON2 P03 | UART0-TXD | PB8 | |
CON2 P02 | UART0-RXD | PB9 | |
CON2 P01 | GND |
Win 10 IoT
banana pi BPI-M64 IOT certifying pass by Microsoft:windows 10 iot core
link: https://azure.microsoft.com/en-us/documentation/articles/iot-hub-tested-configurations/
get start:
test on BPI-M64
discuss on forum: http://forum.banana-pi.org/t/banana-pi-bpi-m64-iot-certifying-pass-by-microsoft-windows-10-iot-core/2090
- schematic diagram:
- google driver : https://drive.google.com/file/d/0B4PAo2nW2KfnUE5tMGItNkZjMzg/view?usp=sharing
- baidu cloud : http://pan.baidu.com/s/1kVRpcYb
- DXF file google download link :https://drive.google.com/file/d/0B4PAo2nW2KfnajlEY0xsdjNxY3c/view?usp=sharing
- battery interface spec : https://drive.google.com/file/d/0B4PAo2nW2KfnSmVuVDhQc0NLdG8/view?usp=sharing
Win 10 IoT
- 2017-1-13 updae Win10 IoT Core beta0.2
- baidu cloud :http://pan.baidu.com/s/1c2ce100
- Win10 IoT Core 10586 beta0.1
- download link : https://drive.google.com/open?id=0B_YnvHgh2rwjODJOSS1TdkRvcEk
- baidu link : http://pan.baidu.com/s/1dEQyGgD
- MD5: 1c09118cd45bf0c3b61d1846710a3649
kernel 4.4
- 2018-4-17 update Ubuntu 16.04.4 with linux kernel 4.4.89
- image name:2018-04-17-ubuntu-16.04-mate-desktop-demo3-k4.4.89-vdpau-3-mic-docker-bpi-r18-avs-aarch64-sd-emmc.img.zip
- Google Drive: https://drive.google.com/open?id=1dlfo9LGNcrc-_cpKd1uJnrNx0PdonBnK
- MD5: 4b7e163d260e58a39ba8905e7ed39943
- Forum pthread:http://forum.banana-pi.org/t/bpi-r18-avs-new-image-ubuntu-16-04-4-with-linux-kernel-4-4-89-2018-4-17/5435
Kernel 3.10.105
- 2017-08-14 update based on ubuntu 16.04.3 LTS Mate Desktop (64-bit),support BPI-M64 kernel 3.10.105
- Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjN1h1U0xDYUxET00/view?usp=sharing
- baidu cloud: http://pan.baidu.com/s/1pLkbdTT
- MD5: ae34baa840874276858d936a7ca85c4f
- Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-2017-08-14-ubuntu-16-04-mate-desktop-beta-aarch64-bpi-m64-sd-emmc/3695
- 2017-08-13 debian 8.9 jessie Mate Desktop (64-bit),support BPI-M64 kernel 3.10.105
- Google Drive:https://drive.google.com/file/d/0B_YnvHgh2rwjazlNRTRHei1NbmM/view?usp=sharing
- baidu cloud:http://pan.baidu.com/s/1eSeTQeA
- MD5: 9ddf067457ebaf193de63c5c7141446a
- Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-2017-08-13-debian-8-jessie-mate-desktop-preview-aarch64-bpi-m64-sd-emmc/3694
Android 6.0
- 2017-05-11 apdate
- HDMI-Version
- Google Drive:https://drive.google.com/open?id=0B_YnvHgh2rwjcF9USm1MWWtxSXc
- Baidu Cloud:https://pan.baidu.com/s/1bHWhlW
- MD5: f85281213b9c5b88008a487dd1b6963c
- LCD-Version
- Google Drive:https://drive.google.com/open?id=0B_YnvHgh2rwjdHpFbHJMQWtsbFk
- Baidu Cloud:https://pan.baidu.com/s/1kVJVPGV
- MD5:be27e4eced96d3de81d46e512fd978eb
- forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-android-6-0-version-v3/3240/4
- Image lownload link :https://www.armbian.com/bananapi-m64/
- Armbian OS aarch64
Others
- others image ,you can download at forum : http://forum.banana-pi.org/c/BPI-M64/M63image
