Getting Started with Triode-Car
Revision as of 06:49, 30 June 2021 by Wind (talk | contribs)
Triode-Car 配合 BPI:AI AI开发板使用
产品信息
香蕉派_Triode-Car
Control With LM393 Chip
Hardware Introduction
There is a button to switch between two modes on the Triode-Car. One of which is using the built-in LM393 comparator chip, and the other is with the Micro: bit or BPI: bit.
When using the built-in LM393 chip, it has only one function, to track dark lines, it consists of the Line-Following Circuit, Voltage Comparing Circuit, and the Motor Circuit.
The Triode-Car uses two pairs of photoresistor and LED on the bottom side to enable its line tracking feature. When the LED light reflecs on bright and dark surfaces, the resistance of the photoresistor will change drastically.
The photoresistor used on Triode-Car is the GL5506, this photoresistor can have a resistance as high as 0.2MΩ in the dark(10Lux), while in the light(400~600Lux), it can have a resistance as low as a 2-5KΩ.
(Bright resistance: Tested after shining with 400~600Lux light for 2 hours, then shine it with a standard 10Lux, with a color temperature of 2854K light source.) (Dark resistance: Tested on the 10th second after shutting off the 10Lux light source.)
The Voltage Comparing Circuit includes the LM393 chip and several resistors. The LM393 consists of two independent precision voltage comparators with a low offset voltage. Its use is to compare two input voltages, then changes the output voltage accordingly. When the positive voltage from the comparator is higher than reverse voltage, the output will output high signal. When the positive voltage is lower than reverse voltage, it will output low signal. The LM393's output is open collector type, so a pull high resistor is needed here.
Motor Circuit
The S8550 PNP triode plays an important role in the motor circuit. It uses a small base current and a negative base voltage to control a larger emitter-collector current. With a maximum collector current of 1.5A, it can be used as a low level switch.
Control Circuit
As the picture shown above, when the car shifts towards the left, the right photoresistor will be directly on top of the line, therefore, its resistance will increase. Conversely, the left resistor, will shift away from the line, its resistance will decrease. At this point, the voltage from LL will be lower than LR. The U1A comparator's positive voltage will be higher than reverse voltage, triggering pin 1 to pull high. Conversely, U1B's positive voltage will be lower than reverse voltage, pin 7 will pull low, making the left motor move. The car shifts right, R6 and D2 moves away from the dark line until the left sensors detect the dark line. The concept is similar as before, the car repeats the actions above to progress forward.
Use MakeCode to Control the Triode-Car
This is a tutorial on how to control the Triode-Car with Micro:bit Makecode.
Beginner Tutorial
Adding the Triode-Car Extention to Control with Micro: bit
It is recommended for beginners to install the extension blocks by typing in the extensions search bar: " https://github.com/bpi-steam/pxt-triodecar" to add extentions. Click to import the Triode-Car extension pack.
1. As the blocks shown, the car will stop after bootup or reset. 2. Pressing down button A and B at the same time will make the car go forward. 3. Press A to turn Right. 4. Press B to turn Left.
Example link:https://github.com/Wind-stormger/Makecode/blob/master/microbit-Triode-car_motor_control_1.hex
Project files can be downloaded and edit locally by importing to MakeCode, or flash it directly onto the Micro:bit via USB to run it directly.
调整电机转速
例程如下图所示,按一次A按钮转速加1档,按一次B按钮转速减1档,Micro:Bit显示当前挡位数值。
采集巡线检测电路的电压模拟信号
硬件原理参考“巡线检测电路”中的介绍。
例程如下图所示,在程序中,每间隔100ms通过USB串口将读取到的左右两个传感器的电压模拟值发送给电脑,在MakeCode中打开控制台即可查看实时接收到的信息。
蓝牙控制
micro:bit支持蓝牙通讯,应用蓝牙扩展积木进行编程,在支持蓝牙通讯的Apple或Android设备上安装APP即可通过蓝牙无线控制。
适用iPhone或iPad: 官方APP micro:bit App Store链接
适用Android手机或平板:第三方APP microbit-blue Github链接或 [https://play.google.com/store/apps/details?id=com.kitronik.blemove 第三方APP Kitronik Move Google Play链接]
高阶教程
校准巡线检测电路
分析校准的步骤:
例程如下图所示。
由于例程较为复杂,所以给出一些必要的说明:
巡线行驶
例程如下图所示。
基础教程
高阶教程
基础教程
高阶教程
