Getting Started with M5/M2Pro
Revision as of 07:34, 8 June 2021 by Dangku (talk | contribs) (Prepare)
Banana Pi BPI-M5
Amlogic S905X3 Processor
  • Mali-G31 MP2 GPU @ 650Mhz
  • System Memory – 4GB LPDDR4
  • Weight – 48grams
aml-flash-tool is a linux platform opensource flash tool for Amlogic android image.
Android DTB overlay
2 i2c2 enable i2c 2
3 i2c3 enable i2c 3
4 sdio enable sdio
5 uart1 enable 2 pins uart 1
7 uart2 enable 2 pins uart 2
How to apply a new dtbo
1. ADB command via sysfs
 restarting adbd as root
 remount succeeded
 bananapi_m5:/ # reboot
 console:/ $
 console:/ $ su
 console:/ #
 console:/ #
 console:/ # reboot
3. Settings App(To-Do)
       Amlogic multi-dtb tool
       Single dtb detected
 find 2 dtbos
 dtbos to be applied: 1
 Apply dtbo 1
Install OpenGapps
2. Download device_id.apk.
udisk:
 --wipe_cache
sdcard:
 --wipe_cache
watch this video on bilibili
IR Remote Control Custom
  • Android keycode.
push remote.cfg back
 # adb root
 # adb remount
 # adb shell
 work_mode = 1
 repeat_enable = 0
 debug_enable = 1
 max_frame_time = 1000
3. Get the remote keycode
custom_code = 0xfe01
 # adb root
 # adb remount
 # adb shell
 work_mode = 1
 repeat_enable = 0
 debug_enable = 1
 custom_name = nec-test
 fn_key_scancode = 0xffff
 cursor_left_scancode = 0xffff
 cursor_up_scancode = 0xffff
 cursor_down_scancode = 0xffff
 cursor_ok_scancode = 0xffff
 release_delay = 80
 map_size = 13
 key[0] = 0x74
 key[1] = 0x1008b
 key[2] = 0x90066
 key[3] = 0x20069
 key[4] = 0xa006a
 key[5] = 0x50067
 key[6] = 0x4006c
 key[7] = 0x6001c
 key[8] = 0x30072
 key[9] = 0xb0073
 key[10] = 0x40009e
 key[11] = 0x4800a4
 key[12] = 0x440071
5. Reboot the board
 $ apt-get install pv
Install Image to SDcard
 $ sudo apt-get install pv
Install Image to EMMC
4. Install with dd command, umount mmcblk0p1 and mmcblk0p2 partition if mounted automatically. Actually bpi-copy is the same as this dd command.
Build Linux Source Code
2. Build the bsp source code
 # Overlays to load
 # Example combinations:
 #   spi0 i2c0 i2c1 uart0
 #   hktft32
 #   hktft35
1. Build and install wiringPi
 $ cd amlogic-wiringPi
 $ chmod a+x build
 $ sudo ./build
4. Extract this tool
 $ ls -l logo/
5. Copy the boot-logo.bmp.gz
 $ adb root
 $ adb remount
 $ adb reboot fastboot
 $ fastboot device
 1234567890      fastboot
 $ fastboot reboot
Boot Sequence
 Board ID = 1
 Set cpu clk to 24M
 Set clk81 to 24M
 Use GP1_pll as DSU clk.
 DSU clk: 1200 Mhz
 CPU clk: 1200 MHz
 Set clk81 to 166.6M
 board id: 1
 fw parse done
 PIEI prepare done
 fastboot data verify
 result: 255
 DDR4 probe
 Board ID = 1
 Set cpu clk to 24M
 Set clk81 to 24M
 DSU clk: 1200 Mhz
 CPU clk: 1200 MHz
 Set clk81 to 166.6M
 eMMC boot @ 0
 sw8 s
 board id: 1
 fw parse done
 PIEI prepare done
 00000000
 emmc switch 1 ok
 ddr saved addr:00016000
 00000000
   remount succeeded
   1234567890	fastboot
   OKAY [  0.044s]
   finished. total time: 0.044s
   OKAY [  0.047s]
   finished. total time: 0.047s
   erasing 'bootloader'...
   OKAY [  0.059s]
   finished. total time: 0.059s
   erasing 'bootloader-boot0'...
   OKAY [  0.036s]
   finished. total time: 0.036s
   erasing 'bootloader-boot1'...
   OKAY [  0.035s]
   finished. total time: 0.035s
   bananapi_m5_v1#amlmmc erase 1
   start = 0,end = 57343
   start = 221184,end = 30535679
   start = 0,end = 8191
   bananapi_m5_v1#reset
   resetting ...
   bananapi_m5_v1#
   bananapi_m5_v1#reboot sdboot
   reboot mode: sdboot
   reboot dev: sd
   before value = 0!
   after value = 4f5244c0!
   resetting ...
   bl2_stage_init 0x01
   board id: 1
   BPI: try boot from sdcard
   reading boot.ini
   reading Image.gz
   reading uInitrd
   reading overlays/i2c0.dtbo
   reading overlays/spi0.dtbo
   reading overlays/uart1.dtbo
   bananapi_m5# mmc erase 0 1000
 $ sync
Wifi/BT support
1. Android test and support.
 rtl8723bu wifi/bt(usb)
 rtl8188eu wifi(usb)
 rtl8821cu wifi/bt(usb)
 rtl8822cs wifi/bt(sdio/uart)
How to enable Android Wifi/BT
2. Linux test and support.
 rtl8188eu wifi(usb)
 rtl8192eu wifi(usb)
 rtl8811au wifi(usb)
 rtl8812au wifi(usb)
 rtl8812bu wifi(usb)
How to enable Linux Wifi
SDIO/UART type:
2). Configure the dtb overlay
  # Overlays to load
  #   hktft32
  #   hktft35
How to enable Linux Bluetooth
Netplan
Linux Wifi STA mode
network:
  version: 2
  renderer: networkd
  wifis:
    wlan0:
      dhcp4: true
      access-points:
        "bananapi":
           password: "123456789"
Linux Wifi AP mode
$ iw list
network:
version: 2
renderer: NetworkManager
wifis:
  wlan0:
    dhcp4: no
    access-points:
      "bananapi":
         mode: ap
         band: 2.4GHz
         channel: 6
         auth:
           key-management: psk
network:
version: 2
wifis:
  wlan0:
    dhcp4: no
    access-points:
      "bananapi":
         mode: ap
         band: 5GHz
         channel: 36
         auth:
           key-management: psk
network:
version: 2
renderer: networkd
ethernets:
  wlan0:
    dhcp4: no
    addresses:
      - 192.168.11.1/24
2). Install hostapd
$ sudo apt install hostapd
interface=wlan0
ssid=bananapi
driver=nl80211
auth_algs=1
wpa=2
wpa_passphrase=123456789
wpa_key_mgmt=WPA-PSK
rsn_pairwise=CCMP
#bridge=br0
beacon_int=500
#SSID not hidden
ignore_broadcast_ssid=0
hw_mode=a
channel=36
max_num_sta=8
### IEEE 802.11n
ieee80211n=1
#require_vht=0
### IEEE 802.11ac
ieee80211ac=1
#require_vht=0
#vht_oper_chwidth=1
### WMM
wmm_enabled=1
INTERFACESv4="wlan0"
  option routers 192.168.11.1;
5). Start Service
6). Routing configuration.
sysctl net.ipv4.ip_forward=1
Coreelec
1. Get the source code.
More info refer to Coreelec official website and github
image download: https://download.banana-pi.dev/lib/898779c1-94be-4627-9a56-d8cec971e877/file/Public/Images/BPI-M5/coreELEC/CoreELEC-Amlogic-ng.arm-9.2-devel-1607997111-Bananapi_M5.img.gz
