Banana Pi BPI-ZERO
- 512MB DDR 3 SDRAM.
- Mini HDMI.
- Quick strart your BPI-M2 zero Quick Start Banana pi SBC
HardWare Specification of Banana pi BPI-M2 zero | |||
CPU | H2+ Quad-core Cortex-A7 H265/HEVC 1080P | ||
GPU | Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 | ||
Memory \(SDRAM\) | 512M \(shared with GPU\) | ||
Onboard Storage | TF card \(Max. 64GB\) | ||
Onboard Network | NOPE | ||
Onboard WIFI | SDIO AP6212(option AP6181、AP6335) | ||
Video Input | A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL,3 Supports SM pixel camera sensor ,4 Supports video capture solution up to 1080p@30fps | ||
Video Outputs | Supports Mini HDMI Port | ||
Audio Output | Mini HDMI | ||
Power Source | Micro USB with 5V/2A | ||
USB 2.0 Ports | one USB 2.0 OTG | ||
Buttons | Power Button, Reset Button | ||
Low-level peripherals | 40 Pins Header,compatible with Raspberry Pi 3 | ||
uart GPIO\(1x3\) pin | UART, ground | ||
LED | Power led & Status led | ||
IR | nope | ||
Supported OS | Android, Ubuntu, Debian, Rasberry Pi Image | ||
Product size | 65mm × 30mm | ||
Weight | 35g |
CON2-P01 | VCC-3V3 | ||
CON2-P02 | VCC-5V | ||
CON2-P04 | VCC-5V | ||
CON2-P06 | GND | ||
CON2-P09 | GND | ||
CON2-P14 | GND | ||
CON2-P17 | VCC-3V3 | ||
CON2-P18 | PC4 | PC4 | |
CON2-P20 | GND | ||
CON2-P23 | SPI0-CLK | PC2 | |
CON2-P24 | SPI0-CS | PC3 | |
CON2-P25 | GND | ||
CON2-P26 | PC7 | PC7 | |
CON2-P30 | GND | ||
CON2-P34 | GND | ||
CON2-P39 | GND | ||
24 PIN CSI Camera connector of Banana pi BPI-R2 | |||
CN3-P01 | NC | ||
CN3-P02 | GND | ||
CN3-P03 | CSI0-SDA | PE13 | |
CN3-P04 | CSI0-AVDD | ||
CN3-P05 | CSI0-SCK | PE12 | |
CN3-P10 | CSI0-DVDD | ||
CN3-P11 | CSI0-DOVDD | ||
CN3-P12 | CSI0-D7 | PE11 | |
CN3-P13 | CSI0-MCLK | PE1 | |
CN3-P14 | CSI0-D6 | PE10 | |
CN3-P15 | GND | ||
CN3-P16 | CSI0-D5 | PE9 | |
CN3-P17 | CSI0-PCLK | PE0 | |
CN3-P18 | CSI0-D4 | PE8 | |
CN3-P19 | CSI0-D0 | PE4 | |
CN3-P20 | CSI0-D3 | PE7 | |
CN3-P21 | CSI0-D1 | PE5 | |
CN3-P22 | CSI0-D2 | PE6 | |
CN3-P23 | GND | ||
CN3-P24 | CSI0-DOVDD |
jumper CON3 of Banana pi BPI-R2 | |||
CON3 P01 | GND |
Opnewrt
Zero power with GPIO 5V input
- Allwinner documents:
Android 4.4
- 2017-11-12 update Android 4.4
- Google Drive:https://drive.google.com/open?id=1TywrMLLxqJj23ql2jyzLruZw18V_XwX3
- Baidu Cloud : https://pan.baidu.com/s/1c2pTXUo
- Forum pthread:
- Image Link:
- Forum thread:
RetroPie
- Image Link:
- RetroPie for Banana Pi M2 Zero v.1.2.1 beta http://www.nintendont.it/download/nintendont-retropie-banana-pi-m2-zero-v-1-2-1-beta/
- Forum thread:
Ubuntu 16.04 mate desktop 2017-11-13
- Image Link:
- Forum thread:
