香蕉派 BPI-M5
BPI-M5介绍
- Mali-G31 GPU图形处理器
- 4GB LPDDR4内存
- 16GB eMMC 板载存储.
- 4 USB 3.0 端口
- 1 GbE 千兆网口
- HDMI 输出
开发快速上手
硬件接口
香蕉派BPI-M5 硬件规格表 | |||
Memory | 4 GB LPDDR4 | ||
OS | Android and Linux |
香蕉派BPI-M2 Pro ,BPI-M5 与 Odroid C4 和 Raspberry Pi 4硬件规格比较表
香蕉派 BPI-M2 Pro | 香蕉派 BPI-M5 | Odroid C4 | 树莓派 4 | ||
GPIO PIN 定义
BPI-M5 40PIN GPIO 定义 (CON2)
CON1-P01 | VCC-3V3 | ||
CON1-P02 | VCC5V | ||
CON1-P04 | VCC5V | ||
CON1-P06 | GND | ||
CON1-P09 | GND | ||
CON1-P14 | GND | ||
CON1-P15 | GPIOX_7 PWM_F | ||
CON1-P17 | VCC-3V3 | ||
CON1-P20 | GND | ||
CON1-P25 | GND | ||
CON1-P30 | GND | ||
CON1-P33 | GPIOX_6 PWM_A | ||
CON1-P34 | GND | ||
CON1-P39 | GND | ||
BPI-M5调试串口定义 UART(CON1)
CON2-P1 | GND |
CON2-P2 | UART0-RX |
CON2-P3 | UART0-TX |
开发资料
软件源代码
Android系统
Linux系统
documents
- BPI-M5 schematic diagram :链接: https://pan.baidu.com/s/1yljIQnudjSvbugY49OrAyg 提取码: meug
- BPI-M5 PCB DXF file: 链接: https://pan.baidu.com/s/1ODfDjKYb56B7JzpYttZwiQ 提取码: hitx
- Amlogic S905x3 datasheet : https://drive.google.com/file/d/18iptZ09U8_4BlWoGMY3b7pcJVoSt_9Ro/view?usp=sharing
系统镜像
- 2020-12-11 release, Android 9.0 with kernel 4.9.113
- Download: 2020-12-11-bpi-m5-android-9-emmc.zip
- MD5: 962325face002250ad4254f7c4625f30
- 2020-12-10 release, Ubuntu Mate Desktop 18.04 with kernel 4.9.236
- Download: 2020-12-10-ubuntu-18.04-mate-desktop-bpi-m5-aarch64-sd-emmc.img.zip
- MD5: 28e4f4e130949fa8257297303fc81139
- 2020-12-10 release, Ubuntu Mate Desktop 20.04 with kernel 4.9.236
- Download: 2020-12-10-ubuntu-20.04-mate-desktop-bpi-m5-aarch64-sd-emmc.img.zip
- MD5: f95d69985e19f5c04179b3986e7bab10
- 2020-12-10 release, Ubuntu Server 20.04 with kernel 4.9.236
- Download: 2020-12-10-ubuntu-20.04-server-bpi-m5-aarch64-sd-emmc.img.zip
- MD5: d918ebb98ae0d6ff00096193bd6bb059
- 2020-12-10 release, Debian Buster with kernel 4.9.236
- Download: 2020-12-10-debian-10-buster-bpi-m5-aarch64-sd-emmc.img.zip
- MD5: 483b31ef3f64b3794b2ec204c1d9da95
CoreELEC
