Banana Pi BPI-M2M
- Allwinner R16/A33 Quad Core ARM Cortex A7 CPU.
- 512MB DDR3 SDRAM.
- 8G eMMC flash
- CSI camera interface
- DSI display interface
- how to burn image : Quick Start Banana pi SBC
- how to development BPI-M2 Magic : Getting Started with M2M
| Banana Pi M2 Magic | |
| CPU | Allwinner R16 ARM Cortex-A7 Quad-Core |
| GPU | PowerVR SGX544MP1 Comply with OpenGL ES 2.0 OpenCL 1x, DX9_3 |
| Memory | 512MB LPDDR3 (shared with GPU) |
| Storage | On Board 8GB eMMC Flash, Micro SD-Card slot. |
| Network | Wi-Fi 802.11 b/g/n (AP6212) + Bluetooth BT4.0 |
| Video Input(s) | A CSI input connector allows for the connection of a designed camera module |
| Video Output(s) | MIPI Display Serial Interface (DSI) for raw LCD Panel |
| Audio Input(s) | On board microphone |
| Audio Output(s) | 3.5mm jack |
| USB ports | USB 2.0 PORT (x1), USB OTG (x1) |
| Remote | Not IR Receiver |
| Switches | Reset, Power and U-boot |
| Size & Weight | 51x51mm, 48g |
| OS | Android and Linux |
| 40 PIN GPIO of Banana pi BPI-M2 Magic | |||
| PIN number | Default Function | Function2:GPIO | |
| CON1-P01 | VCC-3V3 | ||
| CON1-P02 | DCIN | ||
| CON1-P03 | TWI1-SDA | PH5 | |
| CON1-P04 | DCIN | ||
| CON1-P05 | TWI1-SCK | PH4 | |
| CON1-P06 | GND | ||
| CON1-P07 | PWM1 | PH1 | |
| CON1-P08 | UART2-TX | PB0 | |
| CON1-P09 | GND | ||
| CON1-P10 | UART2-RX | PB1 | |
| CON1-P11 | UART3_TX | PH6 | |
| CON1-P12 | AP-PCM-CLK-CTS | PG11 | |
| CON1-P13 | UART3_RX | PH7 | |
| CON1-P14 | GND | ||
| CON1-P15 | LVDS_V1N | PD21 | |
| CON1-P16 | UART2-RTS | PB2 | |
| CON1-P17 | VCC-3V3 | ||
| CON1-P18 | UART2-CTS | PB3 | |
| CON1-P19 | SPI0_MOSI | PC0 | |
| CON1-P20 | GND | ||
| CON1-P21 | SPI0_MISO | PC1 | |
| CON1-P22 | LVDS_V1P | PD20 | |
| CON1-P23 | SPI0_CLK | PC2 | |
| CON1-P24 | SPI0_CS | PC3 | |
| CON1-P25 | GND | ||
| CON1-P26 | LVDS_VCN | PD25 | |
| CON1-P27 | LVDS_V0N | PD19 | |
| CON1-P28 | LVDS_VCP | PD24 | |
| CON1-P29 | LVDS_V0P | PD18 | |
| CON1-P30 | GND | ||
| CON1-P31 | LVDS_V2N | PD23 | |
| CON1-P32 | LVDS_V2P | PD22 | |
| CON1-P33 | LVDS_V3N | PD27 | |
| CON1-P34 | GND | ||
| CON1-P35 | AP-PCM-SYNC | PG10 | |
| CON1-P36 | LVDS_V3P | PD26 | |
| CON1-P37 | PL11-EINT11 | PL11-EINT11 | |
| CON1-P38 | AP_PCM_DIN | PG13 | |
| CON1-P39 | GND | ||
| CON1-P40 | AP-PCM-DOUT | PG12 | |
| CSI Camera pin define of Banana pi BPI-M2 Magic | |||
| CN3-P01 | NC | ||
| CN3-P02 | GND | ||
| CN3-P04 | CSI0-AVDD | ||
| CN3-P10 | CSI0-DVDD | ||
| CN3-P11 | |||
| CN3-P15 | GND | ||
| CN3-P16 | CSI0-D5 | PE9 | |
| CN3-P18 | CSI0-D4 | PE8 | |
| CN3-P19 | CSI0-D0 | PE4 | |
| CN3-P20 | CSI0-D3 | PE7 | |
| CN3-P21 | CSI0-D1 | PE5 | |
| CN3-P22 | CSI0-D2 | PE6 | |
| CN3-P23 | GND | ||
| CN3-P24 | CSI0-AFVCC | ||
- DSI Pin Name**
| MIPI DSI PIN define of Banana pi BPI-M2 Magic | |||
| CN2-P01 | DSI-D0N | ||
| CN2-P02 | DSI-D0P | ||
| CN2-P03 | DSI-D1N | ||
| CN2-P04 | DSI-D1P | ||
| CN2-P05 | DSI-CKN | ||
| CN2-P06 | DSI-CKP | ||
| CN2-P07 | DSI-D2N | ||
| CN2-P08 | DSI-D2P | ||
| CN2-P09 | DSI-D3N | ||
| CN2-P10 | DSI-D3P | ||
| CN2-P11 | NC | ||
| CN2-P12 | NC | ||
| CN2-P13 | TP-SDA | PH3 | |
| CN2-P14 | TP-SCK | PH2 | |
| CN2-P15 | TP-INT | PB5 | |
| CN2-P16 | TP-RST | PB6 | |
| CN2-P17 | LCD-BL-EN | PL4 | |
| CN2-P18 | LCD-RST | PL5 | |
| CN2-P19 | LCD-PWR-EN | PB7 | |
| CN2-P20 | LCD-PWM | PH0 | |
| CN2-P21 | GND | ||
| CN2-P22 | GND | ||
| CN2-P23 | PS | ||
| CN2-P24 | PS | ||
The header CON4 is the UART0 interface. kernel debug uart is UART2 of 40pin header.
| Uart PIN define of Banana pi BPI-M2 Magic | |||
| CON3-P1 | GND | ||
| CON3-P2 | UART0-RX | ||
| CON3-P3 | UART0-TX | ||
Opnewrt
TinaLinux
About Tina-IoT Linux
BPI-M2 Magic R16 Tina Linux V1.0 have public,Come and try
Tina Linux development by Allwinner TinaTEAM, it base on OpenWrt,To build an embedded Linux distributions,The purpose of this release is to provide a quick learning and development is simple and convenient mass production Linux TurnKey solutions.
TinaLinux source code on github:
- allwinner R16 chip Datasheet-V1.4 (1): https://drive.google.com/file/d/0B4PAo2nW2KfnVW9FSUpPX2FLcU0/view?usp=sharing
- Allwinner_R16_User_Manual_V1.2: https://drive.google.com/file/d/0B4PAo2nW2KfnUjZUNVdyN1RkVlE/view?usp=sharing
- AXP223 Datasheet V1.0_en :https://drive.google.com/file/d/0B4PAo2nW2KfnckxWZFBBMUNWSUk/view?usp=sharing
- BPI-M2 Magic DXF file public https://drive.google.com/file/d/0B4PAo2nW2KfnalhDRG5EclU1dHM/view?usp=sharing
Android 6.0 LCD7-Version
- 2019-08-06 update ,BPI-M2 Magic Android 6 new image release ,This release is for banana pi M2m board with BPI 7" panel, and it is based on Android 6.0 Operation system with kernel 3.4.
- Android 6
- Fetures Map: http://wiki.banana-pi.org/M2M_Image_Map#Kernel_3.4
- Google Drive : https://drive.google.com/open?id=1QH9v37XCpOAxFJLaazsSzzFyFj2LdPtg
- Baidu Drive : https://pan.baidu.com/s/1xO9jZQsNXoTAmdpDFBiwYg (PinCode:alyr)
- MD5 : 90e2f11480b54ba6fa5b630770913a85
- FAQ
- How to install Android image,Please see here: http://wiki.banana-pi.org/Install_Linux_%26_Android_images_on_Banana_pi_SBC#Install_Android_Images
- Android 6
- Image Link:
- Google Drive: https://drive.google.com/open?id=0B_YnvHgh2rwjbkNuaEt4OTlyQjg
- Baidu Drive:https://pan.baidu.com/s/1qY8zAmo
- Forum thread:
- 2021-03-24 release, Ubuntu Mate Desktop 16.04 with kernel 3.4.39
- Download: 2021-03-24-ubuntu-16.04-mate-desktop-bpi-m2m-sd-emmc.img.zip
- MD5:
- 2021-03-24 release, Ubuntu Server 16.04 with kernel 3.4.39
- Download: 2021-03-24-ubuntu-16.04-server-bpi-m2m-sd-emmc.img.zip
- MD5:
- 2019-05-11 update This release is for banana pi M2 Magic board which is based on R16, and it is based on Ubuntu 16.04 Operation system with kernel 3.4.
- .BPI-M2M Ubuntu Server 16.04 Features Map : http://wiki.banana-pi.org/M2M_Image_Map
- LCD7 SD & Emmc version images:
- Google Drive : https://drive.google.com/file/d/1jrW7BKWblRyYYpgB6SEMnRWoGjREVexe/view
- Baidu Drive : https://pan.baidu.com/s/1QIXnZHg7MS9pR7pRXvZu1w (PinCode:n20l)
- MD5 : 9dcd344f0a6433bc649301930599d45b
- CD7 Emmc version image:
- Notes : Because sd pins and uart0 pins are the same, so we have to use uart2 as debug console before, and I release this image is just in order to release uart2 to use and set uart0 as debug console.
- How to burn image:you just need to use m2m boot from a sd image, then use sd image to install this emmc image on emmc.
- Google Drive : https://drive.google.com/open?id=1vJqO2O47Ekq9diny7kZQKBQLXylCGuTG
- Baidu Drive : https://pan.baidu.com/s/1xE5tpw0DqNAV2mqKg_TbpQ (PinCode:awpy)
- MD5 : 9f576cfaeb0329648b14b541ff2f5dd4
- FAQ:For more operation details please see Wiki: http://wiki.banana-pi.org/Getting_Started_with_M2M
- forum pthread: http://forum.banana-pi.org/t/bpi-m2m-r16-new-image-release-ubuntu-server-16-04-2019-05-09/9205
- Unbutu 16.04 2018-08-25 Image Link: This release is for banana pi M2 Magic board which is based on R16, and it is based on Ubuntu 16.04 Operation system with kernel 3.4.
- BPI-M2M Ubuntu 16.04 Features Map:http://wiki.banana-pi.org/M2M_Image_Map
- LCD 7’-Version Google Drive : https://drive.google.com/open?id=14LH4NGAyfeCXhnKlzc75-K6p2gmO5RrM
- LCD 7’-Version Baidu Drive : https://pan.baidu.com/s/17jiGC4fCSTfVKPWUgh-VXA
- Forum pthread:http://forum.banana-pi.org/t/bpi-m2m-r16-new-image-release-ubuntu-16-04-2018-08-25/6596
- For more operation details please see Wiki: http://wiki.banana-pi.org/Getting_Started_with_M2M
- Unbutu 16.04 2018-01-04 Image Link:
- Baidu Drive:https://pan.baidu.com/s/1kVKjxOF
- Google Drive: https://drive.google.com/file/d/1GKwVO03Z5VHOaodVVyboLC-F7r_qyk7e/view?usp=sharing2
- MD5: df72548c26cd42b8138f334f5b383f31
- Unbutu 16.04 2017-10-23 Image Link:
- Baidu Drive:http://pan.baidu.com/s/1hsGhxWS
- Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjU2xWQ3otX0JZb1E/view?usp=sharing
- MD5: 23cd3f0891d8ad274984eea3f4981eab
Tina Linux
- 2017-11-15 update : tina astar m2magic
- more about Tina Linux Tina Linux
- image name : 2017-11-15-tina_astar-m2magic_card0_burn_by_PhoenixCard.img
- google downlad : https://drive.google.com/open?id=13iVMJJVY6i8GJjMjoAyk62IDW83MagDX
- forum pthread: http://forum.banana-pi.org/t/bpi-m2-magic-new-image-2017-11-15-tina-astar-m2magic-card0-burn-by-phoenixcard/4184
