BPI-K210 RISC-V AIoT board
Revision as of 02:37, 11 March 2021 by Sinovoip (talk | contribs)
BPI-AI Kendryte K210 RISC-V
BPI Q-Car kit with BPI:AI board
BPI-K210 AIoT
BPI-K210 RISC-V 64bit design
About BPI-K210
BPI-K210 is the first Banana Pi board with RISC-V chip design.An integrated artificial intelligence SOC chip solution that can accommodate neural network models, using a new risc-v instruction set for the field of artificial intelligence and edge computing. The main target market is the IoT and STEAM education market
Type Applications
  • AI for Edge Computing
  • Smart Building
  • Medical equipment
  • Automation & Process Control
  • Robot
  • IoT applications
  • 8MB On-Chip SRAM 128Kbit One-Time Programmable Memory (OTP) ,Read Only Memory (ROM)
  • DMA
  • Camera and screen interface
  • WiFI and BT support
  • JTAG, OpenOCD support
About Kendryte K210 chip
BPI-K210 hardware
BPI-K210 interface
BPI-K210 Spec
CPU Kendryte K210 64-bit RISC-V CPU Dual-Core, up to 400MHz
ROM 128Kbit
SRAM 8MB On-Chip SRAM 128Kbit One-Time Programmable Memory (OTP)
Flash SPI flash 128Mbit
Display LCD display interface
Camera 1 Camera interface
Voice 1 Head set,1 Speaker,1 Mic port
Power 5V@1A micro USB poweror or lithium battery power
GPIO 26 PIN GPIO
Debug JTAG debug interface
Wi-Fi TW-03 WiFI module onboard
LEDs 1 Power LED and 1 state LED
Sizes 56x85mm
BPI-K210 GPIO PIN define
BPI-K210 software
Source code on github
