Banana Pi BPI-F2P
Banana Pi BPI-F2P
BPI-F2S with Heat sinks ,PoE module and RTC battery on board
BPI-F2S with F2S-SUB baord for 4G,Wifi,and SATA support
BPI-F2S back
Banana Pi BPI-F2S FPGA board
SunPlus SP7021 Diagram
SunPlus SP7021
Application direction
  • Smart Audio
  • Smart Payment system
about SunPlus SP7021
characteristics of the SP7021
  • Easy-to-use LQFP package.
  • Single 3.3V power*.
  • 10-year supply guarantee.
  • And much more...
  • SoC – Sunplus SP7021 “Plus1” with a quad-core Cortex-A7 processor @ 1.0 GHz, one Arm A926 microprocessor, an 8051 core to handle I/Os, and 128MB or 512MB DDR3 DRAM.
  • Storage – 8GB eMMC flash, microSD card slot
  • Video Output – HDMI 1.4 output
  • Camera I/F – MIPI CSI connector
  • Connectivity – 2x 10/100M Ethernet
  • USB – 2x USB 2.0 host ports, 1x micro USB port
  • Expansion
2 USB header interface
40-pin GPIO header compatible
7.4V Lithium battery power supply interface
RTC battery interface
PoE function support
  • Debugging – 3-pin header for UART console, SWD ICE port
  • Security – TPM 2.0 via ST33TPH2EI2C secure element
  • Power Supply – 12VDC via power barrel jack
  • Dimensions – 130x85mm
  • Temperature Range – -40C ~ +85°C
BPI-F2P-SUB baord
we also design a expansion board for BPI-F2P , it support 2 SATA interface and 4G module support interface
Source code on github
All image download link:
Ubuntu Linux
  • BPI-F2P new image 2021-01-29 update:Ubuntu server 20.04.1 and Ubuntu mate 20.04.1 image,this image support boot from SD card and eMMC flash
2021-01-29-ubuntu-mate-20.04.1-desktop-armhf-ext4-v5.4.35-bpi-f2p.img.zip: Ubuntu Desktop system, Support HDMI interface to display Desktop.
google link https://drive.google.com/file/d/1eHOMRnR1YWVxIPkBe0vtWvoMJQ9g79J2/view?usp=drivesdk
2021-01-29-ubuntu-server-20.04.1-armhf-ext4-v5.4.35-bpi-f2p.img.zip: Ubuntu Server System, it don’t include Desktop, only support serial console.
google link : https://drive.google.com/file/d/1zHua_PLDInUG1bnplN-3uKZcTgX3AFno/view?usp=drivesdk
Baidu link:https://pan.baidu.com/s/1JD3Yn9TYRd_nR8A1AJpqdQ Pincode:fv8e
  • BPI-F2P new image:Ubuntu server 20.04.1 and Ubuntu mate 20.04.1 image
BPI-F2P Ubuntu server 20.04.1 image :https://drive.google.com/file/d/1nbHUcwl2Zh1ZKJlZ1223zM8YBr-onKEs/view?usp=drivesdk
BPI-F2P Ubutntu mate 20.04.1 image:https://drive.google.com/file/d/1HFkckuPsuBploMnntMqPQ3cwqnqY6Y_-/view?usp=drivesdk
discuss on fourm: http://forum.banana-pi.org/t/bpi-f2p-new-image-ubuntu-server-20-04-1-and-ubuntu-mate-20-04-1-image/11608
support BPI-F2P-SUB baord . all function test fine
  • BPI-F2P new image: Ubuntu mate 18.04.2 2020-08-16
google driver: https://drive.google.com/file/d/1zVGCs4i8EUAZa4UL_TU0WHko5IXUlsGu/view?usp=drivesdk
baidu link : https://pan.baidu.com/s/1vsdH_PDQ_oJdP3WBEG43Pg Pincode:3qgs
discuss on forum: http://forum.banana-pi.org/t/bpi-f2p-new-image-ubuntu-mate-18-04-2-linux-kernel-5-4-2020-08-16/11442
  • 2019-12-25 update :ubuntu mate 18.04 desktop 2019-12-25 base on kernel 4.19.37
file name : 2019-12-25-ubuntu-mate-18.04.2-beta1-desktop-armhf+raspi-ext4-bpi-f2s.img.zip
google link:https://drive.google.com/file/d/1_TJzJPMm89Fb9Fji1PddMPas-EEO-IGw/view
discuss on forum:http://forum.banana-pi.org/t/bpi-f2s-new-image-ubuntu-mate-18-04-desktop-2019-12-25/10454
Kail Linux
file name:2019-12-25-kali-linux-2019.4-rpi3-nexmon-bpi-f2s.img.zip
google link:https://drive.google.com/file/d/19G49t288CKKLGokI-jQOs9h7rtsxGBGo/view?usp=drivesdk
password: root/toor
discuss on forum:http://forum.banana-pi.org/t/bpi-f2s-new-image-kail-linux-2019-4-nexmon-2019-12-25/10453
Debian Linux
file name: 2019-11-29-debian-10-buster-mate-desktop-beta-bpi-f2s-sd-emmc.img.zip
google download link: https://drive.google.com/file/d/1MpjDeUk4H-EXzaxpuywgbgRaM8YXoXjI/view
Discuss on forum: http://forum.banana-pi.org/t/bpi-f2s-new-image-debian-10-buste-bpi-f2s-sd-emmc-2019-11-26/10270
CentOS linux
file name:2019-12-25-CentOS-Userland-7-armv7hl-RaspberryPI-KDE-1908-sda.raw.xz-bpi-f2s.img.zip
google link:https://drive.google.com/file/d/1Is-BS7lvCUrRBkO7wCjn4q51eI7Yof-l/view
password:root/centos
discuss on forum:http://forum.banana-pi.org/t/bpi-f2s-new-image-centos-userland-armv7hl-raspberrypi-kde-1908-sda-2019-12-25/10452
Fedora-Mate
Mozilla IoT gateway
file name:2019-12-25-rpi-gateway-0.10.0-bpi-f2s.img.zip
google link:https://drive.google.com/file/d/1wPDeqQpKce-I81fQ638HE_ogl-MDkOOB/view?usp=drivesdk
Mozilla gateway getting started guide:https://iot.mozilla.org/docs/gateway-getting-started-guide.html
discuss on forum :http://forum.banana-pi.org/t/bpi-f2s-new-image-mozilla-iot-rpi-gateway-0-10-0-2019-12-25/10455
Yocto Linux
github link: https://github.com/tibbotech/yocto_layers
aliexpress : https://www.aliexpress.com/item/4001268419883.html
taobao: https://item.taobao.com/item.htm?ft=t&id=624363638904
