BPI-Bit
Overview: ESP32
Overview: ESP32
Overview: back
BPI:bit hardware
BPI:bit hardware description
BPI:bit interface
BPI:bit edge interface
BPI-bit software
BPI:bit for webduino
BPI: bit Webduino Firmware Burning
Burning method:
Select ESP32 DownloadTool:
set file name Position
2 partitions.bin 0x8000
3 boot_app0.bin 0xe000
4 bit_default.bin 0x10000
- SpiFlashConfig:
SpiFlashConfig
1 SPI SPEED 40NHz
2 SPI MODE DIO
3 FLASH SIZE 32Mbit
5 BAUD 1152000
During the burning process:
Finished:
Burn time is about 20s
Webduino source code on github
BPI:bit for arduino
