Banana Pi BPI-M5
BPI-M5 Introduction
Key Features=
- Mali-G31 GPU
- 4GB LPDDR4
- 16GB eMMC flash
- 4 USB 3.0
- 1 GbE ethernet
- HDMI output
Hardware inerface
Memory | 4 GB LPDDR4 | ||
OS | Android and Linux |
BPI-M5 VS Odroid C4 VS Raspberry Pi 4
BPI-M5 VS Odroid C4 VS RPI 4 | ||||
Banana Pi BPI-M5 | Odroid C4 | Raspberry Pi 4 | ||
Processor | Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz | Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz | Broadcom BCM2711, Quad core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz | |
GPU | Mali-G31 MP2 GPU | Mali-G31 MP2 GPU | Broadcom VideoCore VI | |
RAM | 4GB LPDDR4 | DDR4 4GiB with 32-bit bus width | 2GB, 4GB or 8GB LPDDR4-3200 SDRAM | |
Storage | micro SD card slot & 16GB eMMC flash on board | micro SD card slot , eMMC connector for option | micro SD card slot, non EMMC | |
Network | GbE ,Optional WiFi USB dongle | GbE | GbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE | |
Video Output | 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) | 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) | 2 × micro-HDMI 2.0 | |
Audio Output | 3.5mm jack and 1 x HDMI digital output | Optional SPDIF optical output | 3.5 mm analogue audio-video jack | |
DSI | N/A | N/A | 2-lane MIPI DSI display port | |
CSI | N/A | N/A | 2-lane MIPI CSI camera port | |
USB | USB 3.0 x 4 TYPE C | USB 3.0 x 4, 1 x Micro USB 2.0 port (OTG) | 2 USB 3.0 ports; 2 USB 2.0 ports; | |
Power | 5 volt @3A via Micro USB (TYPE C) | 1 x DC power jack (Outer diameter : 5.5mm, inner diameter : 2.1mm) | 5V DC via USB-C connector (minimum 3A*) | |
IR | Yes | Yes | N/A | |
GPIO | 40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). | 40 x GPIO pins | 40-pin GPIO header, populated | |
Button | Reset, user and U-boot | N/A | N/A | |
LED | Power Status and Activity status | Power Status and Activity status | Power Status and Activity status | |
Dimensions & weight | 85mm x 56mm, 48g | 85mm x 56mm 59g | 88 mm × 58 mm, 46 g | |
Linux Support | Linux & Android | Linux & Android | Linux & Android |
Linux BSP source code
Linux BSP code: https://github.com/BPI-SINOVOIP/BPI-M5-bsp
- 2020-12-11 release, Android 9.0 with kernel 4.9.113
- Download: 2020-12-11-bpi-m5-android-9-emmc.zip
- MD5: 962325face002250ad4254f7c4625f30
- 2020-12-10 release, Ubuntu Mate Desktop 18.04 with kernel 4.9.236
- Download: 2020-12-10-ubuntu-18.04-mate-desktop-bpi-m5-aarch64-sd-emmc.img.zip
- MD5: 28e4f4e130949fa8257297303fc81139
- 2020-12-10 release, Ubuntu Mate Desktop 20.04 with kernel 4.9.236
- Download: 2020-12-10-ubuntu-20.04-mate-desktop-bpi-m5-aarch64-sd-emmc.img.zip
- MD5: f95d69985e19f5c04179b3986e7bab10
- 2020-12-10 release, Ubuntu Server 20.04 with kernel 4.9.236
- Download: 2020-12-10-ubuntu-20.04-server-bpi-m5-aarch64-sd-emmc.img.zip
- MD5: d918ebb98ae0d6ff00096193bd6bb059
- 2020-12-10 release, Debian Buster with kernel 4.9.236
- Download: 2020-12-10-debian-10-buster-bpi-m5-aarch64-sd-emmc.img.zip
- MD5: 483b31ef3f64b3794b2ec204c1d9da95
CoreELEC
