Banana Pi BPI-R64
Revision as of 16:22, 20 December 2020 by Sinovoip (talk | contribs) (Ubuntu)
Banana Pi BPI-R64 with MT7622
Overview:banana Pi BPI-R64
4G with USB 4G module via USB
BPI-R64 case
MTK MT7622
  • 1G DDR3 SDRAM
  • MTK7615 4x4ac wifi (option)
  • support 1 SATA interface
  • (1) USB 3.0
  • POE function support
Hardware Revision
SDRAM 1 GB DDR3
SATA support 1 SATA interface
USB 1 USB 3.0 host
Buttons Reset button
IR PIN define with GPIO
DC Power 12V/2A with DC in
Sizes 148 mm × 100.5mm
Weight 100g
PoE support
more PoE module spec
4G support
BPI-R64 GPIO Pin define
  • BPI-R64 schematic diagram
Amazon AWS Greengrass
Release
OpenWRT & LEDE
  • Mainline OpenWRT image
https://drive.google.com/drive/folders/1LQaxUAWPh6Q3QbLEIxN3JP3soIDEPzGD
discuss on forum : http://forum.banana-pi.org/t/r64-mainline-openwrt-image/11415
Fetures Map:
  • 2020-12-05 Ubuntu 18.04 with kernel 5.4.0
donload link : https://download.banana-pi.dev/f/bec503ed6ec048ffa087/
supports 4G Module(EC20)
Fetures Map:
AArch64 Linux
Fetures Map:
