Getting Started with M5/M2Pro
[hide]Introduction
- Mali-G31 MP2 GPU @ 650Mhz
- System Memory – 4GB LPDDR4
- Weight – 48grams
- 3. The SOC rom first boot sequence is emmc, so board can't bootup from SDcard if the emmc is bootable with any image flashed, more info about the image boot sequence please refer to board boot flow.
- 4.
- 2. Download the AML Burn Card Maker tool for create a bootable sdcard to flash android image to emmc, only support windows.
- 3. Download the latest android image.
- Error creating thumbnail: Unable to save thumbnail to destination
- 2. Make sure bootable EMMC is formatted from sector 0 if you want bootup from SDcard, and make sure bootable SDcard is formatted if you want bootup from EMMC(because uboot read bootscript file from mmc:1 first, which is SDcard dev, This is used for quickly SDcard bootup debug or flash image to EMMC while EMMC is bootable).
- 3. Install bpi-tools on your Linux PC. If you can't access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
- 4. Download Linux latest image.
- 5. Default login: pi/bananapi or root/bananapi
Install Image to SDcard
- 2. Install bpi image with Etcher on Windows, Linux and MacOS.
Install Image to EMMC
- 4. Install with dd command, umount mmcblk0p1 and mmcblk0p2 partition if mounted automatically.
$ sudo apt-get install pv $ sudo unzip -p xxx-bpi-m5-xxx.img.zip | pv | dd of=/dev/mmcblk1 bs=10M status=noxfer
Build Linux Source Code
- 3. If you want build uboot and kernel separately, please download the u-boot the kernel only, get the toolchains and configuration from BPI-M5-bsp
- 1. DTB overlay is used for 40pin gpios multi-function configuration and install in vfat BPI-BOOT/overlays
root@bananapi:~# ls /media/pi/BPI-BOOT/overlays/ custom_ir.dtbo pwm_b-backlight.dtbo spi0.dtbo ds3231.dtbo pwm_c-beeper.dtbo uart1_cts_rts.dtbo hifi_pcm5102a.dtbo pwm_cd-c.dtbo uart1.dtbo hifi_pcm5122.dtbo pwm_cd.dtbo uart2.dtbo i2c0.dtbo pwm_ef.dtbo waveshare_tft24_lcd.dtbo i2c1.dtbo pwm_ef-f.dtbo waveshare_tft35c_lcd.dtbo pwm_ab.dtbo sdio.dtbo waveshare_tft35c_rtp.dtbo
root@bananapi:~/amlogic-wiringPi# gpio readall +-----+-----+---------+------+---+--- M5 ---+---+------+---------+-----+-----+ | I/O | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | I/O | +-----+-----+---------+------+---+----++----+---+------+---------+-----+-----+ | | | 3.3V | | | 1 || 2 | | | 5V | | | | 493 | 8 | SDA.2 | ALT1 | 1 | 3 || 4 | | | 5V | | | | 494 | 9 | SCL.2 | ALT1 | 1 | 5 || 6 | | | 0V | | | | 481 | 7 | IO.481 | IN | 1 | 7 || 8 | 1 | ALT1 | TxD1 | 15 | 488 | | | | 0V | | | 9 || 10 | 1 | ALT1 | RxD1 | 16 | 489 | | 479 | 0 | IO.479 | IN | 1 | 11 || 12 | 1 | IN | IO.504 | 1 | 504 | | 480 | 2 | IO.480 | IN | 1 | 13 || 14 | | | 0V | | | | 483 | 3 | IO.483 | IN | 1 | 15 || 16 | 1 | IN | IO.476 | 4 | 476 | | | | 3.3V | | | 17 || 18 | 1 | IN | IO.477 | 5 | 477 | | 484 | 12 | MOSI | ALT4 | 1 | 19 || 20 | | | 0V | | | | 485 | 13 | MISO | ALT4 | 1 | 21 || 22 | 1 | IN | IO.478 | 6 | 478 | | 487 | 14 | SLCK | ALT4 | 1 | 23 || 24 | 1 | OUT | SS | 10 | 486 | | | | 0V | | | 25 || 26 | 1 | IN | IO.492 | 11 | 492 | | 474 | 30 | SDA.3 | IN | 1 | 27 || 28 | 1 | IN | SCL.3 | 31 | 475 | | 490 | 21 | IO.490 | IN | 1 | 29 || 30 | | | 0V | | | | 491 | 22 | IO.491 | IN | 1 | 31 || 32 | 0 | IN | IO.495 | 26 | 495 | | 482 | 23 | IO.482 | IN | 0 | 33 || 34 | | | 0V | | | | 503 | 24 | IO.503 | IN | 1 | 35 || 36 | 0 | IN | IO.432 | 27 | 432 | | 505 | 25 | IO.505 | IN | 0 | 37 || 38 | 1 | ALT4 | IO.506 | 28 | 506 | | | | 0V | | | 39 || 40 | 0 | IN | IO.500 | 29 | 500 | +-----+-----+---------+------+---+----++----+---+------+---------+-----+-----+ | I/O | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | I/O | +-----+-----+---------+------+---+--- M5 ---+---+------+---------+-----+-----+
