Getting Started with M5/M2Pro
Revision as of 08:36, 9 December 2020 by Dangku (talk | contribs) (Linux)
Banana Pi BPI-M5
Amlogic S905X3 Processor
  • Mali-G31 MP2 GPU @ 650Mhz
  • System Memory – 4GB LPDDR4
  • Weight – 48grams
3. The SOC rom first boot sequence is emmc, so board can't bootup from SDcard if the emmc is bootable with any image flashed, more info about the image boot sequence please refer to board boot flow.
4.
2. Download the AML Burn Card Maker tool for create a bootable sdcard to flash android image to emmc, only support windows.
3. Download the latest android image.
