Getting Started with M5/M2Pro
Banana Pi BPI-M5
Amlogic S905X3 Processor
preliminary specifications
  • Mali-G31 MP2 GPU @ 650Mhz
  • System Memory – 4GB LPDDR4
  • Weight – 48grams
Android development
Linux development
