BPI-EAI80 AIoT board
Introduction BPI-EAI80
BPI-AI Kendryte K210 RISC-V
BPI-Bit with ESP32 design
BPI-K210 RISC-V AIoT board
BPI-EAI80 AIoT board use Edgeless EAI80 chip design .it have Dual-Cortex M4F@200MHz 500DMIPS and AI-NPU:CNN-NPU @300 MHz 300GOPS. support LVDS pannel and camera interface. onboard wifi
Target Applications
  • Voice Control - Key words real-time control
  • Computer Vision - Detection & recognition of object and biology (Face, Body, Gesture), vSLAM
  • End-side AIoT - Edge computing, Info. Security,Off-line equipment control, System monitor
  • Sensor, Attendance machine, AD display, Wearable,devices, Smart unmanned retail, STEM education
  • Home & Building Automation – White goods,HVAC, Lighting, Security system, IoT gateways
  • Industrial Computing - EBS, PLCs, M2M, T&M,Auto-factory, HMI control assembly, QR/bar code
  • Motor Control & Power Conversion - VFC,FOC, 3D/thermal Printers, ADAS, UAV, Robots
  • STEAM education
Hardware Spec
  • CPU Dual-Cortex M4F@200MHz 500DMIPS
  • AI-NPU:CNN-NPU @300 MHz 300GOPS
  • 2D Graph :Dual-Camera Max
  • SDRAM 8M
  • LCD 1024*768 TFT-LCD
  • CANBUS 2.0 A/B
  • ESP8266 Wifi onboard
  • 40PIN GPIO (share with LCD )
  • 2 Mic support
  • Size: 86x54mm
Linux SDK Compile and burn
BPI-EAI80 board , EAISeries SDK UserGride
BPI-EAI80 board , EAISeries SDK UserGride:
https://drive.google.com/file/d/18kmhdspeWu05nkt3DMM2rAd1oz-30rQR/view?usp=sharing
please install KeliSDK:
https://github.com/BPI-SINOVOIP/BPI-EAI80-bsp/tree/master/KelisSDK
https://github.com/BPI-SINOVOIP/BPI-EAI80-bsp/blob/master/Keil.EAISeries_DFP.1.4.1.pack
windows version:
1. Install EAI80 SDK (windows ) 2. PLease install ※Keil.EAISeries_DFP.1.4.1.pack§first; 3. Demo board should connect with PC through J-Link and SWD interface. All the operations refer to "EAISeries_SDK_UserGuide" in detail.
EAI80 Demo:
Demo path: EAI80_SDK_v1.0\ugelis\kelis_example\ai_example\ai Demo functions:
  • 1st.Voice - Key words recognition;
  • 2rd.Computer Vision - Hand gesture detection and recognition;
  • 3nd.Computer Vision - Human dody detection.
About Edgeless EAI series
EAI Series adopt“Dual-CPU+NPU”structure, combine AI ability with real-time and low power embedded MCU. Rich peripherals and HW-security integrated, EAI series are designed to support next-gen. IoT applications, provide single-chip turnkey solution with AI recognition and MCU control. Edgeless Embedded AI Series crossover processor, EAI series,under the wave of AIoT, are launched for smart home, industry, stem education, energy MGT and etc., with AI ability, low power and cost-effective, provide complete HW/SW turnkey solutions. Target to establish the smallest AI+MCU module in the world, promote transboundary innovation, empower end-sides and industries.
  • More advanced structure and performance
  • Lower run and standby power consumption
  • Voice / Computer vision / 2D Graph accelerator
  • Real-time operation / Multiple HW-level security
  • Easy to use / Richer integration / Lower cost
EAI chip Device Summary
EAI series Documents
BPI-EAI80 documents
easy to buy sample
just BPI-EAI80 board: https://www.aliexpress.com/item/1005001514323399.html?spm=5261.ProductManageOnline.0.0.18e94edf6m7Z9f
BPI-EAI80 + 7 Inch Touch Screen + OV5640 camera + power:https://www.aliexpress.com/item/1005001514465394.html?spm=5261.ProductManageOnline.0.0.18e94edf6m7Z9f
taobao: https://item.taobao.com/item.htm?ft=t&id=627834108380
OEM&ODM project: [email protected] [email protected]
