Banana Pi BPI-M4
Revision as of 23:57, 21 May 2020 by Dangku (talk | contribs) (Linux Images)
BPI-M4 with 1GB DDR4
BPI-M4 with 2GB DDR4
Overview:Realtek RTD1395
PoE function support
M.2 and PCIE support
BPI-M4 Case
  • 8G eMMC flash (max 64 GB)
  • USB 2.0 TYPE C
  • PoE function support
Getting Started with M4
Size & Weight 92x60mm, 48g
OS Android and Linux
CON1-P02 DCIN
CON1-P03 I2C1_SDA GPIO-17
CON1-P04 DCIN
CON1-P05 I2C1_SCL GPIO-16
CON1-P07 PWM1 GPIO-21
CON1-P08 UR1_TX GPIO-9
CON1-P10 UR1_RX GPIO-8
CON1-P11 SDIO-D0 GPIO-42
CON1-P12 AIO_BCK GPIO-3
CON1-P13 SDIO-D1 GPIO-43
CON1-P15 SDIO-D2 GPIO-44
CON1-P16 UR1_RTS GPIO-11
CON1-P18 UR1_CTS GPIO-10
CON1-P19 GSPI-MOSI GPIO-31
CON1-P21 GSPI-MISO GPIO-18
CON1-P22 GPIO-47 GPIO-47
CON1-P23 GSPI-SCK GPIO-19
CON1-P24 GSPI-CS GPIO-20
CON1-P26 PWM2 GPIO-22
CON1-P27 SDIO-D3 GPIO-45
CON1-P28 PWM3 GPIO-23
CON1-P29 SDIO-CLK GPIO-41
CON1-P31 SDIO-CMD GPIO-40
CON1-P32 SPDIF GPIO-50
CON1-P33 AIO_CK GPIO-4
CON1-P35 AIO_LRCK GPIO-2
CON1-P36 GPIO-53 GPIO-53
CON1-P37 GPIO-34 GPIO-34
CON1-P38 AI_SD GPIO-5
CON1-P40 AO_SD GPIO-6
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
Source code on github: https://github.com/BPI-SINOVOIP/BPI-M4-bsp
documents
  • BPI-M4 schematic diagram:
google driver:https://drive.google.com/file/d/1A6pj8Y9Ru1_qfMapIdiQnMavEs5xzN5H/view?usp=sharing
Baidu cloud:https://pan.baidu.com/s/1mnn51dwBV5uxpNheBD4vJA pincode: t6cd
google driver: https://drive.google.com/file/d/1xK-DAjdjXiY7BgGcmq7x-aL5g6djznqT/view?usp=sharing
baidu cloud : 链接: https://pan.baidu.com/s/1bSZFMJ2lD_zuQru6Lf27RQ Pincode: 6pb8
Android Images
  • 2020-5-18 update, Android 8.1 with kernel 4.9.119.
Download Android 8.1 image
How to install the Android 8.1 image
Note: Starting with this release, BPI-M4 Android8 image is only support 2GB ddr board because 1GB ddr is not stable and smooth for Android8
  • 2019-6-25 update ,This release is for BPI-M4 which is based on rtd1395,Image is Android 8.1.0 with kernel 4.9.119.
Features Map:http://wiki.banana-pi.org/M4_Image_Map#Android_8.1_HDMI
google link : https://drive.google.com/file/d/1TnJdzlOr-PSNn65MIedHTc3bj2LcNim-/view?usp=sharing
baidu link:https://pan.baidu.com/s/1Y7nH1hy0nQYpl4KCUCacUA pincode:x78f
For detail steps please see here:http://wiki.banana-pi.org/Getting_Started_with_M4#Install_Android
Forum pthread:http://forum.banana-pi.org/t/bpi-m4-android-8-1-demo-image-release-2019-06-25/9401
Linux Images
Ubuntu Mate 18.04, Ubuntu Server 16.04, Raspbian Stretch
  • 2020-05-18 update, Kernel 4.9.119
Download Image
How to Install Image
Ubuntu linux
Debian linux
Google Drive : https://drive.google.com/open?id=1rVrZStsw2PINBhIxCzOLOtYLbtoECmEk
Baidu Drive : https://pan.baidu.com/s/1WcrBkxm5OyBLedCBwaUz6Q (PinCode:e6m3)
MD5 : 300b37cdfa092d72dceddd4f33825b40
Forum Pthread:http://forum.banana-pi.org/t/bpi-m4-bpi-w2-debian10-buster-desktop-new-demo-image-20190813/9712
Issue: if HDMI doesn’t display, please try “ctrl + alt + F1” to change terminal then “ctrl + alt + F7” change to desktop display.
SW2: switch to 0,if insert SD, SD start;if doesn’t insert SD,EMMC start.
Debian 10 buster (32bit)
Raspbian Linux
AArch Linux
Fetures Map:
  • AArch64 Linux Lite
Fetures Map:
