BPI-EAI80 AIoT 开发板
Revision as of 23:21, 29 April 2020 by Sinovoip (talk | contribs) (目标应用)
BPI-EAI80 AIoT开发板介绍
BPI-AI Kendryte K210 RISC-V
BPI-Bit with ESP32 design
BPI-EAI80 AIoT 开发板采用格力零边界EAI80芯片设计.支持Dual-Cortex M4F@200MHz 500DMIPS和AI-NPU:CNN-NPU @300 MHz 300GOPS. 支持LVDS屏接口和摄像头接口,板载wifi,方便的做各种AI物联网应用。
目标应用
  • 语音控制-关键字实时控制
  • 计算机视觉-物体和生物(脸,身体,姿势)的检测和识别,vSLAM
  • 终端AIoT -边缘计算,信息。安全,离线设备控制,系统监控
  • 传感器、考勤机、广告显示、可穿戴设备、智能无人零售
  • 家庭和建筑自动化-白色家电,暖通空调,照明,安全系统,物联网网关
  • 工业计算- EBS, plc, M2M, T&M,Auto-factory, HMI控制总成,二维码
  • 电机控制和功率转换- VFC,FOC, 3D/热敏打印机,ADAS,无人机,机器人
  • STEM教育
  • CPU Dual-Cortex M4F@200MHz 500DMIPS
  • AI-NPU:CNN-NPU @300 MHz 300GOPS
  • 2D Graph :Dual-Camera Max
  • SDRAM 8M
  • LCD 1024*768 TFT-LCD
  • CANBUS 2.0 A/B
  • ESP8266 Wifi onboard
  • 40PIN GPIO (share with LCD )
  • 2 Mic support
  • Size: 86x54mm
硬件接口示意
软件
About Edgeless EAI series
EAI Series adopt“Dual-CPU+NPU”structure, combine AI ability with real-time and low power embedded MCU. Rich peripherals and HW-security integrated, EAI series are designed to support next-gen. IoT applications, provide single-chip turnkey solution with AI recognition and MCU control. Edgeless Embedded AI Series crossover processor, EAI series,under the wave of AIoT, are launched for smart home, industry, stem education, energy MGT and etc., with AI ability, low power and cost-effective, provide complete HW/SW turnkey solutions. Target to establish the smallest AI+MCU module in the world, promote transboundary innovation, empower end-sides and industries.
  • More advanced structure and performance
  • Lower run and standby power consumption
  • Voice / Computer vision / 2D Graph accelerator
  • Real-time operation / Multiple HW-level security
  • Easy to use / Richer integration / Lower cost
EAI chip Device Summary
EAI series Documents
