Banana Pi BPI-F2P
Application direction
- Smart Audio
- Smart Payment system
about SunPlus SP7021
characteristics of the SP7021
- Easy-to-use LQFP package.
- Single 3.3V power*.
- 10-year supply guarantee.
- And much more...
- Expansion
- 2 USB header interface
- 40-pin GPIO header compatible
- 7.4V Lithium battery power supply interface
- RTC battery interface
- PoE function support
- Debugging – 3-pin header for UART console, SWD ICE port
- Dimensions – Still not documented
Source code on github
Ubuntu Linux
Kail Linux
- password: root/toor
Debian Linux
CentOS linux
- password:root/centos
Fedora-Mate
Mozilla IoT gateway
Yocto Linux
