Banana Pi BPI-F2P
![](/images/thumb/e/ed/Banana_Pi_BPI-F2S_2.JPG/300x203x300px-Banana_Pi_BPI-F2S_2.JPG.pagespeed.ic.ydN19Y39Gc.jpg)
Banana Pi BPI-F2P use Sunplus chip design, this is a industrial control board. use Plus1(sp7021) design. it support PoE function with PoE module,and support RS232 and RS485 . so you can use it do a Industrial control gateway.
Application direction
- Smart Audio
- Smart Payment system
about SunPlus SP7021
characteristics of the SP7021
- Easy-to-use LQFP package.
- Single 3.3V power*.
- 10-year supply guarantee.
- And much more...
- Expansion
- 2 USB header interface
- 40-pin GPIO header compatible
- 7.4V Lithium battery power supply interface
- RTC battery interface
- PoE function support
- Debugging – 3-pin header for UART console, SWD ICE port
- Dimensions – Still not documented
Source code on github
Ubuntu Linux
Kail Linux
- password: root/toor
Debian Linux
CentOS linux
- password:root/centos
Fedora-Mate
Mozilla IoT gateway
Yocto Linux
- FPGA TRM-TE0725LP-01_usermanual https://drive.google.com/file/d/1yKsbKSc2VSZgkFH_Oezm_75lD5un8MMT/view?usp=sharing
- Xilinx AI Platform tutorials: https://github.com/Xilinx/Edge-AI-Platform-Tutorials
- Xilinx edge AI platform : https://www.xilinx.com/products/design-tools/ai-inference/edge-ai-platform.html
