BPI-EAI80 AIoT board
Revision as of 20:44, 17 April 2020 by Sinovoip (talk | contribs) (Introduction)
Introduction BPI-EAI80
BPI-AI Kendryte K210 RISC-V
BPI-Bit with ESP32 design
BPI-EAI80 board use Edgeless EAI80 chip design .
About Edgeless EAI series
EAI chip Device Summary
EAI series Documents
