BPI-EAI80 AIoT board
BPI-EAI80 board use Edgeless EAI80 chip design .
About Edgeless EAI series
EAI chip Device Summary
EAI series Documents
- Edgeless EAI series Whitepaper and Embedded AI MCU : https://drive.google.com/file/d/16y-UTRYJbohEmt7lzjNBpO_yiRf6Jwur/view?usp=sharing
- Edgeless EAI series datasheet: https://drive.google.com/file/d/1KSOOAXKe0eLpXGxulQPzuoHqoMPqTq99/view?usp=sharing
- Edgeless EAI series reference manual : https://drive.google.com/file/d/1oviJX3j_HNM-kNA8Ceszbke5KXs3yXua/view?usp=sharing
