10.1 HDMI touch panel
Revision as of 22:00, 12 April 2020 by Sinovoip (talk | contribs) (1024*600 touch panel)
BPI 10.1 HDMI touch panel
this module have HDMI interface on baord ,so it support BPI-M1,BPI-M1+,BPI-M2,BPI-M3,BPI-M64,BPI-M2U,BPI-M2B BPI-R1.
LCD module for Banana Pi board via an conversion board to connect to the LCD connector designed specifically for interfacing to LCD.
Banana pi LCD Connector :The LCD Connector is a stander Type-A HDMI connector which can connect to HDMI-TX.
it support two touch panel
HardWare Specification of 10.1 HDMI panel
TFT LCD MODULE HC101TK20050
TP MODULE GT9271
Panel Size Size 10.1 inches
Resolution 1024 (RGB) x 600
Display Interface HDMI
TP Interface USB-HID
Color Depth 16.7M
Viewing Direction 6 o’clock
Active Area(mm) 222.72(H)x125.28(V)
OutlineDimension(mm) 235(W)×143(H)×5.0( D)
Display Format RGB vertical stripe
Display Mode Normally White
Operation Temperature -20~70℃
Weight (g) TBD
1280*800 touch panel
TFT LCD MODULE HC101I35025NB
TP MODULE ILI2511
Resolution 1280 (RGB) x 800
Color Depth 16.7M
Active Area(mm) 216.96(W) × 135.60(H)
OutlineDimension(mm) 229.46(W) ×149.1(H) ×2.50(D)
Weight (g) TBD
back:
BPI 10.1 touch panel support HDMI interface
cable line
How to use
we have finished all Banana pi boards driver , it support Android,Linux and windows.
banana pi BPI-10 1 HDMI touch screen demo with Linux:https://www.youtube.com/watch?v=R4OKR4vj1Ow&feature=youtu.be
