BPI-UNO32
The BPI:UNO32 (also referred to as BPI-UNO32, stylised as BPI UNO32) is an ESP32 with Xtensa 32bit LX6 single/dual-core processor based embedded system. support Webduino and arduino function.
BPI-UNO32 uses the ESP-WROOM-32 of espressif company as MCU. ESP32 is a single-chip solution integrating 2.4GHz Wi-Fi and Bluetooth dual mode. The 40 nanometer technology of TSMC has the best power consumption, RF performance, stability, versatility and reliability. It can deal with various application scenarios.
Two separate controlled CPU cores, the main frequency can be up to 240MHz, 448KB ROM, 520KB SRAM.
BPI-UNO32 The appearance size is fully matched with Arduino UNO R3
BPI:UNO32 hardware
BPI:UNO32 interface
BPI:UNO32 Spec
CPU Xtensa® 32-bitLX6single / dual core processor
ROM 448KB
SRAM 520KB
Flash 4MB(Onboard),A maximum of 4 Flash/SRAM, each Flash maximum 16MB
Power 5V@1AmicroUSBpoweror 5.5mm 12VDCport
GPIO 12-bits SAR ADC 18 channel, 2\*8-bit D/A converter, 4*SPI, 2*I2S, 2*I2C, 3*UART, Host SD/eMMC/SDIO, Slave SDIO/SPI
Wi-Fi 802.11 b/g/n/e/i 802.11 n\(2.4GHz 150Mbps\) 802.11 e\(Quality of Service\)
Bluetooth BT4.2 & BLE
Buzzer Passive buzzer
LEDs RGB LED/POWER LED/Receive LED/Transmit LED
Sizes 68mm\*53mm
BPI:UNO32 PIN define
BPI-UNO32 software
Ardino IDE
BPI:UNO32 for Arduino
BPI:UNO32 for arduino Source code on Github: https://github.com/yelvlab/BPI-BIT
