Realtek RTD1296 Intelligent voice, video processing platform
Revision as of 04:12, 27 February 2020 by Sinovoip (talk | contribs) (Overview)
Exterior industrial design
Hardware base on Banana Pi BPI-W2
this is a BPI 4.0 Server customization project base on Banana Pi BPI-W2,it with 8G eMMC flash ,and 4G DDR on board, support HDMI in and HDMI out , You can collect the audio and video data of HDMI in, and send them to the display terminal after processing by HDMI out to complete the audio and video services you want to process,also support HDMI bypass funtion, use TS3DV642A0RUAR HDMI bypass chip. Direct connection between IN and OUT when shutdown (continuous electricity). After booting, HDMI IN and HDMI OUT function respectively
Main function
  • Mali T820 MP3 GPU
  • 4G DDR4 SDRAM
  • 8G eMMC flash (Max to 32 G)
  • Realtek rtl8275 b/g/n wifi and BT 4.0 support
  • M.2 Key E interface
  • 1 SATA interface
  • 1XGigabit LAN
  • 1xUSB 3.0 1xUSB 2.0
  • HDMI in & HDMI out support HDMI bypass function
  • TYPE C /Power
  • IR support
Open Source resource
this board base on BPI-W2 ,you can reference Banana Pi BPI-W2
how to begin : Getting Started with W2
cooperative partner
