Banana Pi BPI-F2S
[hide]Introduction
Banana Pi BPI-F2S is the first board with Banana Pi team and SunPlus, this is a industrial-grade board. use Plus1(sp7021) design. this is a industrial-grade board.
Application direction
- Smart Audio
- Smart Payment system
- FPGA education and development
about SunPlus SP7021
characteristics of the SP7021
- Easy-to-use LQFP package.
- Single 3.3V power*.
- 10-year supply guarantee.
- And much more...
note : 40 PIN GPIO compitable Raspberry Pi
- Expansion
- 40-pin GPIO header compatible with Raspberry Pi header
- Debugging – 3-pin header for UART console, 10-pin JTAG header, SWD ICE port
- Dimensions – Still not documented
- Temperature Range – -40C ~ +85°C (at least true for the processor, but not specified for the board itself).
Kit include
- 1. BPI-F2S sunplus board
- 2. FPGA baord: Xilinx Artix-7 XC7A100T,32 MByte QSPI Flash memory,power by single 3.3v
- 3. teaching sheet board : 4 digit 7 segment digital tube teaching,DIP8 socket for SPI flash IP authentication,8 LED lights are used for teaching
- 4. debug tooling
- 5. 12v/2A adapter
FPGA kit documents
Key Features:
- Xilinx Artix-7 XC7A100T-2CSG324C
- 32 MByte Flash memory
- 95 I/O's (42 + 42 + 3 + 8)
- I2C EEPROM
- 7.3 x 3.5 cm form factor
- JTAG/UART connector
- One user LED
Source code on github
Ubuntu Linux
Kail Linux
- password: root/toor
Debian Linux
CentOS linux
- password:root/centos
Fedora-Mate
Mozilla IoT gateway
- FPGA TRM-TE0725LP-01_usermanual https://drive.google.com/file/d/1yKsbKSc2VSZgkFH_Oezm_75lD5un8MMT/view?usp=sharing
- Xilinx AI Platform tutorials: https://github.com/Xilinx/Edge-AI-Platform-Tutorials
- Xilinx edge AI platform : https://www.xilinx.com/products/design-tools/ai-inference/edge-ai-platform.html
- Aliexpress online shop: https://www.aliexpress.com/item/4000516679477.html
- Taobao shop : https://item.taobao.com/item.htm?ft=t&id=610642319814
