香蕉派 BPI-F2S
Revision as of 22:44, 2 December 2019 by Sinovoip (talk | contribs) (characteristics of the SP7021)
File:Banana PI BPI-F2S 4.JPG
sunplus SF7021 chip design
File:Banana PI BPI-F2S 5.JPG
Industrial operating
SunPlus SP7021 Diagram
香蕉派BPI-F2S 是 香蕉派团队 and 凌阳科技首次合作开发的一款工业级应用的开发板, 使用SP7021芯片设计.具有高性能,低功耗的特点; 内嵌 Linux Embed 系统,适合于语音图像处理、通信、便携式工业控制设备等应用场合。 自带高性能处理器,特别适合 AI 人工智能,机器视觉等需要强大运算力的应用;外扩 FPGA 模组,可提供硬件加速,芯片 IP 验证及 SOC 科研及教学应用; BPI-F2S开发板集具有集成度高,优良的布线布局,板面积很小,易于现场测试应用
应用方向
  • IoT物联网/工业互联网控制
  • 智能语音
  • 智能支付系统
  • FPGA 开发与教育
  • 车载网络技术与应用
SunPlus SP7021介绍
SP7021芯片主要特性
  • Easy-to-use LQFP package.
  • Single 3.3V power*.
  • 10-year supply guarantee.
  • And much more...
note : 40 PIN GPIO compitable Raspberry Pi
File:Banana Pi FPGA kit.JPG
Kit include
  • 1. BPI-F2S sunplus board
  • 2. FPGA baord: Xilinx Artix-7 XC7A100T,32 MByte QSPI Flash memory,power by single 3.3v
  • 3. teaching sheet board : 4 digit 7 segment digital tube teaching,DIP8 socket for SPI flash IP authentication,8 LED lights are used for teaching
  • 4. debug tooling
  • 5. 12v/2A adapter
online documents:
Key Features:
  • Xilinx Artix-7 XC7A100T-2CSG324C
  • 32 MByte Flash memory
  • 95 I/O's (42 + 42 + 3 + 8)
  • I2C EEPROM
  • 7.3 x 3.5 cm form factor
  • JTAG/UART connector
  • One user LED
Source code on github
Fedora-Mate
