香蕉派 BPI-R64
[hide]产品介绍
MTK MT7622 芯片
- 1G DDR3 SDRAM
- MTK7615 4x4ac wifi on board
- support 1 SATA interface
- (1) USB 3.0
- POE function support
开始使用
如何使用BPI-R64进行开发 :Getting Started with R64
硬件接口示意
Banana pi BPI-R64 硬件规格 | |||
SDRAM | 1 GB DDR3 | ||
On board Network | 5 10/100/1000Mbps Ethernet with MT7531 switch chip | ||
Wifi | built-in 4x4n 802.11n (800Mbps) sysem-on-chip and MTK7615 4x4ac wifi Module (1733Mbps) on board | ||
USB | 1 USB 3.0 host | ||
Buttons | Reset button | ||
IR | onboard IR receiver | ||
DC Power | 5V/2A with DC in | ||
Sizes | 148 mm × 100.5mm | ||
Weight | 100g |
PoE 网线供电支持
more PoE module spec
4G 支持
2,也可以采用USB接口的扩展模块
BPI-R64 GPIO Pin define
资源
软件源代码
- OpenWRT 官方支持github: https://github.com/openwrt/openwrt/tree/master/target/linux/mediatek/mt7622
文档
- MT7622_Reference_Manual_for_Develope_Board(BPi) :
- MT7531 switch chip datasheet: https://pan.baidu.com/s/1JmYWLA1mwBOYndZPbtz6qQ 提取码: rwr2
- Banana Pi BPI-R64 通过 amazon AWS 认证 : https://devices.amazonaws.com/detail/a3G0h000000OvObEAK/Banana-Pi-R64
- Bpi-r64 quick start (boot from eMMC):http://forum.banana-pi.org/t/bpi-r64-quick-start-boot-from-emmc/9809
Amazon AWS 认证
镜像发布
- Fetures Map:
- Google Drive : https://drive.google.com/open?id=1zrOSS2QJPirSwoK5yJFx10SiOtxRjXP
- Fetures Map:
AArch64 Linux
- Fetures Map:
