BPI-Nano robot 机器人扩展板
arduino Nano robot board
 BPI-Nano arduino Nano
 with BPI-NANO arduino NANO board
BPI-UNO arduino UNO board
BPI-UNO32 with ESP32
BPI-Nano robot 机器人扩展板是为ardino nano板与arduino Nano兼容板设计. 由Harsh Dethe设计,由比派科技生产。
BPI-NANO robot 控制器可用的电机驱动扩展板,支持双路电机控制,单路最大电流可达1A.
Arduino标准插针设计接口,也可给Arduino Nano配合使用。可应用于小型移动机器人的开发。
技术规格
  • 驱动芯片:L293B
  • 逻辑工作电压:5V DC
  • 电机驱动电压:7-12V DC
  • 最大驱动电流:1A(每路)
  • 电机驱动使用引脚:PIN4/5/6/7(Arduino控制器)
  • 平面尺寸:56x57mm
PIN define
BPI-Nano aruino Nano robort GPIO pin define
Pin Function
Digital 2、4 Motor2 Steering control, 2 high level, 4 low level positive turn;Whereas inversion
Digital 3 Motor 2 Enable interface, high level enable
Digital 5 Motor 1 Enable interface, high level enable
Digital 7、8 Motor 1 Steering control, 7 high level, 8 low level positive turn;Whereas inversion
Sample code
//This motor shield use Pin 2,3,4,5,6,7,8 to control the motor
// Just plug the nano into the shield
// Simply connect your motors to M1 ,M2
// Upload the code to BPI-NANO/arduino
// Through serial monitor, type 'a','s', 'w','d','x' to control the motor
// http://www.banana-pi.org/
// Last modified on 20/09/2019
int EN1 = 5;  //Motor 1 Enable
int EN2 = 3;  //Motor 2 Enable
int IN1 = 7;
int IN2 = 8; //Motor 1
int IN3 = 2;
int IN4 = 4; //Motor 2
void Motor1(int ENA, boolean reverse)
         digitalWrite(ENA,HIGH);
        if(reverse)
         digitalWrite(IN1,HIGH);
         digitalWrite(IN2,LOW);
       else
         digitalWrite(IN1,LOW);
void Motor2(int ENB, boolean reverse)
         digitalWrite(ENB,HIGH);
        if(reverse)
         digitalWrite(IN3,HIGH);
         digitalWrite(IN4,LOW);
       else
         digitalWrite(IN3,LOW);
         digitalWrite(IN4,HIGH);
void setup()
   int i;
   for(i=2;i<=8;i++)  //For BPI-NANO Motor Shield
   pinMode(i, OUTPUT);  //set pin 2,3,4,5,6,78 to output mode
   Serial.begin(9600);
void loop()
 int x,delay_en;
 char val;
 while(1)
   val = Serial.read();
   if(val!=-1)
         switch(val)
            case 'w'://Move ahead
                       Motor1(100,true);
                       Motor2(100,true);
                        break;
            case 's'://move back
                       Motor1(100,false);
                       Motor2(100,false);
                        break;
            case 'a'://turn left
                       Motor1(100,true);
                       Motor2(100,false);
                        break;
            case 'd'://turn right
                       Motor1(100,false);
                       Motor2(100,true);
                       break;
              case 'x'://stop
                       digitalWrite(ENA,LOW);
                       digitalWrite(ENB,LOW);
                        break;
