Getting Started with R64
Revision as of 01:04, 10 October 2019 by Sinovoip (talk | contribs) (→GPIO)
Overview:Banana Pi BPI-R64
File:BPI-R64 POE 1.jpg
Read more: Banana Pi BPI-R64
  • 1G DDR3 SDRAM
  • Built-in 4x4n 802.11n/Bluetooth 5.0 system-on-chip
  • MTK7615 4x4ac wifi on board
  • Support 1 SATA interface
  • 1 Port USB 3.0
  • POE function support
 * Using your USB-Serial Connect debug console on R64
Load your first image on R64
 * apt-get install pv
 4.After step 3, then you can insert your TF card into R64, and press power button to setup R64
Ubuntu On Emmc
 1. If you want to install image on EMMC, follow these steps:
 * Burn an image to sd card, and set up R64 with sd card.
 * Copy the image which name contains "xxx-emmc-xxx" to U disk.
 * mount U disk to R64, then use bpi-copy to burn image to Emmc.
   bpi-copy  <XXX.img.zip>
 * After this, reboot R64.
 * Remove SD & power on.
Network-Configuration
GPIO
40 Pins Definition
  • echo 431(22+409) > /sys/class/gpio/export
  • echo out > /sys/class/gpio/gpio431/direction
  • echo 1 > /sys/class/gpio/gpio431/value
PWM Control
SPI touch panel
Sata
  • If you want to use Sata interface on R64, you need to give GPIO90 low level
    • echo 499 > /sys/class/gpio/export
    • echo out > /sys/class/gpio/gpio499/direction
    • echo 0 > /sys/class/gpio/gpio499/value
  • Test a TOSHIBA HDD DISK, the Read/Write performance are below:
Read from disk: 50MB/s command: dd if=/dev/sda of=/dev/null bs=1M count=1024
Write to disk: 38MB/s command: dd if=/dev/zero of=/dev/sda bs=1M count=1024
Read from disk: 360MB/s command: dd if=/dev/sda of=/dev/null bs=1M count=1024
Write to disk: 200MB/s command: dd if=/dev/zero of=/dev/sda bs=1M count=1024
PCIe
  • If you want to use PCIe interface on R64, you need to give GPIO90 high level
    • echo 1 > /sys/class/gpio/gpio499/value
  • PCIe supports EC-25 4G module.
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On R64 console:
BT & BLE on R64
R64 BT Architectural
  • BLE on R64
  • Input Command "btmw-test", you will enter to "btmw_test_cli" command line
  • Here are some example commands:
    • MW_GAP name 7622_BT /*rename bt device*/
    • MW_GAP info /*check local BT device info*/
    • MW_GATTC scan /* start ble scan*/
    • MW_GATTC stop_scan /* stop ble scan*/
R64 LAN Function
  • LAN eth interface is eth2, use "ifconfig eth2 up" to enable it.
  • Config the ip, "ifconfig eth2 192.168.1.1".
  • Config your dhcp server, "vim /etc/dhcp/dhcpd.conf", add these configurations.
  • Start dhcp server, "dhcpd eth2".
  • then config iptables and set package forward.
    • Add "net.ipv4.ip_forward=1" to "/etc/sysctl.conf"
    • "/sbin/sysctl -p" to make forward work
    • "iptables -t nat -A POSTROUTING -s 192.168.1.1/24 -o eth3 -j MASQUERADE"
Ap mode on R64
  • Find "mt_wifi.ko" and insmod it.
    • insmod ./lib/modules/4.4.92-BPI-R64-Kernel/extra/mt_wifi.ko
  • Then you will see ra0 and rai0.
  • ra0 is MT7622 2.4G wifi
  • rai0 is MT7615 5G wifi
2.4G WiFi
  • Use "ifconfig ra0 up" to enable it.
  • Config the ip, "ifconfig ra0 192.168.1.1".
  • Start dhcp server, "dhcpd ra0".
5G WiFi
  • Use "ifconfig rai0 up" to enable it.
  • Config the ip, "ifconfig rai0 192.168.1.1".
  • Start dhcp server, "dhcpd rai0".
  • MT7622 Reference Manual for Develope Board(BPi)
Google Drive:https://drive.google.com/open?id=1UhaIM9ork1O9cNO-t6ENMVVamB75AThV
BaiDu Drive:https://pan.baidu.com/s/1KduFT2MUvMs2FhOF4A8kQQ
Reference Link
http://forum.banana-pi.org/
