BPI:bit MoonCar Kit
BPI:bit MoonCar
BPI:bit MoonCar
BPI:bit MoonCar
MoonCar with BPI:bit
BPI:Bit MoonCar(Web:bit MoonCar), developed by Webduino and iCShop,made by BPI, is a self-propelled car specially designed for the BPI:Bit(Web:bit)/Micro:bit development board. It has built-in tracking function, color sensing, infrared emission and reception, and buttons. Combined with Web:Bit, it can let the dot matrix display patterns of various colors.The foot position of ultrasonic wave is reserved in front, which can realize the function of automatic obstacle avoidance.More fun ways to control yourself through the Web:Bit education!
power source
MoonCar comes with two tiny metal motors and a training wheel, which are of better quality and durability than the motors with plastic gearboxes. The training wheels are specially made of non-metallic materials, which can reduce the noise caused by striking the ground.
Sending and receiving messages
The front of the MoonCar is equipped with a pair of infrared emission and reception, through the general infrared remote control to its instructions. Infrared transmitters can send messages to communicate with other mooncars, making it much more playable.
buzzer (make a sound)
On the right side of the MoonCar is a passive buzzer that can be programmed to produce different sounds, such as an electronic organ or an alarm or a ringtone. I can edit the statements generated by different notes and pauses to make MoonCar sound like talking.
Magic lantern
Linear sensor (Track the line running)
Color identification
Expansion function
Considerate design
Conclusion
Use with BPI:bit
Sourcode on github
Mooncar project : https://github.com/iCShopMgr/MoonCar
Use with Micro:bit
