Banana Pi BPI-R64
[[File:
MTK MT7622
- 1G DDR3 SDRAM
- MTK7615 4x4ac wifi (option)
- support 1 SATA interface
- (1) USB 3.0
- POE function support
Read more for development :Getting Started with R64
Hardware Revision
| SDRAM | 1 GB DDR3 | ||
| SATA | support 1 SATA interface | ||
| On board Network | 5 10/100/1000Mbps Ethernet | ||
| Wifi | built-in 4x4n 802.11n (800Mbps) sysem-on-chip and MTK7615 4x4ac wifi Module (1733Mbps) (option) | ||
| USB | 1 USB 3.0 host | ||
| Buttons | Reset button | ||
| DC Power | 12V/2A with DC in | ||
| Weight | 100g | ||
PoE support
more PoE module spec
4G support
BPI-R64 GPIO Pin define
- BPI-R64 Linux BSP : https://github.com/BPI-SINOVOIP/BPI-R64-bsp
- OpenWRT: https://github.com/openwrt/openwrt/tree/master/target/linux/mediatek/mt7622
- MT7622 Reference Manual for Develope Board(BPi) : https://drive.google.com/file/d/1cW8KQmmVpwDGmBd48KNQes9CRn7FEgBb/view?usp=sharing
- Banana Pi BPI-R64 debian Linux boot demo and bootlog:http://forum.banana-pi.org/t/banana-pi-bpi-r64-debian-linux-boot-demo-and-bootlog/8155
Release
- easy to buy sample: BPI official Aliexpress shop
