BPI NB-IoT Linaro 96Boars
1.NB-IoT module:
- Model and Frequency band:
SIM card:
- Micro SD SIM Slot
2,MCU:
Hardware inerface
Harware spec
| HardwareSpecification of BPi BC95-LINARO | |||
| Soc | STM32F103RBT6 | ||
| CPU | ARM 32-bit Cortex™-M3 CPU @72MHz | ||
| SDRAM size | 20 KB | ||
| Flash size | 128KB | ||
| Power | 5V/2A via MicroUSB / 2PIN Battery Connector | ||
| Low-level peripherals | 40 Pins Header \(2.0mm Pitch\), 32×GPIOs,Some of which can be used for specific functions including UART, I2C, SPI, PWM | ||
| On board Network | Quectel BC95 | ||
| On board SIM | MicroSD SIM SloteSIM\(option\) | ||
| USB | 1 USB 2.0 host | ||
| Buttons | Reset button, User button | ||
| Leds | 1 Power status Led and 5 other Leds | ||
| Sizes | 60mm×30mm | ||
| Weight | 10g | ||
Dimensions
GPIO (CON1) define
40 PIN GPIO (CON1) define:
Software introduction
1 ,Lite OS brief Huawei
2,BC95 software brief:
Command format:
- Searching network steps:
- AT+NBAND?**//QueryBand
- AT+CFUN?**//value :1
- AT+CIMI**//Query IMSI number
- AT+CSQ**/Query the signal strength
- AT+NUESTATS**//Query module status
- AT+CGATT?**//Back + CGATT: 1 indicates that the attachment is successful, with a delay of about 30s
- AT+CEREG?**//Search for network status, 1 for Internet, 2 for Network
- AT+CSCON?**//Query the connection status, 1 CONNECT, 0 IDLE
Manually configure network if fails to register network automatically:
- AT+CFUN=1 AT+CIMI**//Execute CFUN = 1, wait for 4 seconds to query IMSI, if it can be found that the card has been identified;If not, please check the card is inserted and confirm whether it is a USIM card.
- AT+NBAND?**//Query frequency band information.
- AT+CEREG=1**//Set to automatically register network registration status, when the module registered on the network, will report URC.**AT+CGDCONT=1,“IP”,“APN”**//The APN is configured locally \(or not configured\) for local access.
- AT+COPS=1,2,"46000"**//Specify PLMN search, PLMN configuration.
- AT+CSQ**//Query signal strength.
- AT+NUESTATS**// Query module status
Quecte BC95 datasheet (CN version) https://drive.google.com/file/d/0B4PAo2nW2KfnWnRVczZXV3lPZmc/view?usp=sharing
STM32F103(LD) datasheet.
Discuss on forum : http://forum.banana-pi.org/t/bpi-nb-iot-linaro-96boars-with-quecte-bc95-module-developent-board/3416/2
