BPI NB-IoT Linaro 96Boars
1.NB-IoT module:
  • NB-IoT module:Quectel BC95-B5/8/20 or BC95-G
  • Model and Frequency band:
SIM card:
  • Micro SD SIM Slot
  • e-SIM optional(footprint reserved on the board)
  • Antenna: IPEX antenna connector
2,MCU:
Hardware inerface
Harware spec
HardwareSpecification of BPi BC95-LINARO'
Soc STM32F103RBT6
CPU ARM 32-bit Cortex™-M3 CPU @72MHz
SDRAM size 20 KB
Flash size 128KB
Power 5V/2A via MicroUSB / 2PIN Battery Connector
Low-level peripherals 40 Pins Header \(2.0mm Pitch\), 32×GPIOs,Some of which can be used for specific functions including UART, I2C, SPI, PWM
On board Network Quectel BC95
On board SIM MicroSD SIM SloteSIM\(option\)
USB 1 USB 2.0 host
Buttons Reset button, User button
Leds 1 Power status Led and 5 other Leds
Sizes 60mm×30mm
Weight 10g
Dimensions
40PIN GPIO (CON1) define
