Getting Started with M2 Ultra & Berry
- 1 Introduction
- 2 Development
- 2.1 Basic Development
- 2.2 Advanced Development
- 2.3 FAQ
- 3 Reference Link
BPI-M2U
Overview Banana PI BPI-M2 Ultra
- 2GB DDR3 SDRAM
- 8 GB eMMC storage
- SATA Interface
BPI-M2 Berry
Banana Pi BPI-M2 Berry is a quad-core mini single board computer built with Allwinner V40 SoC. It features 1GB of RAM . It also has onboard WiFi and BT. On the ports side, the BPI-M2 Ultra has 4 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, a DC power port, and last but not least, a SATA port..
- Read more about : Banana Pi BPI-M2 Berry
- Quad Core ARM Cortex A7 CPU V40.
- 1GB DDR3 SDRAM.
- SATA Interface
Load your first image on M2U
1.You could download latest image from our forum * Here is an example image link: http://forum.banana-pi.org/t/banana-pi-bpi-m2u-berry-new-image-release-raspbian-jessie-8-0-2018-5-24/5812 2.Install bpi-tools on your system * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 3.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card. 4.After step 3, then you can insert your TF card into M2U, and press power button setup M2U
Load your first image on M2U EMMC
* Run your M2U with TF card * Copy "xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to your USB disk * Plug your USB disk in M2U * After M2U recognise USB disk, execute "bpi-copy xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to install image on EMMC * Then power off M2U, take TF card out, power on M2U
How to build uboot & kernel
Install tools
- apt-get udpate
- apt-get install pv
Clone code
- git clone: https://github.com/BPI-SINOVOIP/BPI-M2U-bsp.git
- ./build.sh
SATA
1. Mount SATA on M2U
- "mount /dev/sdx /mnt/xxx"
OTG
1. On M2U console:
2. On PC terminal:
LCD 5" & LCD 7"
- Find "BPI_M2U_LCD7.img.gz"
Touch screen
Use iperf3 to test gmac
1. On PC Terminal:
- Execute "iperf3 -s"
2. On M2U console:
- Execute "bluetoothctl"
- Execute these commands:
WiFi on M2U
network={
ssid="ssid"
psk="password"
priority=1
We use HDF5640 camara.
IR function
- Execute "getevent"
WringPi
File System
Install Qt5.7 & Qtcreator
1.Prepare a 32Gb TF card
2.Use GParted to resize root point '/' as 32Gb
3.apt-get install libxcb*
4.download qt5.7
5.make & make install
6.apt-get install qtcreator
7.Config qtcreator
